1. AC Question's Avatar
    Hello everyone, I don't know if this question was been asked before (pardon me if that is the case). I have a Samsung gear 1 running Tizen OS and a Note 3 (rooted). The watch works perfectly fine, however when I go out of range the Bluetooth disconnects which is fine, the problem is when I get back in range it never connects by itself and I have to go to samsung gear and manually reconnects which is frustrating. It used to work perfectly fine until I updated to Tizen.
    04-19-2015 10:28 AM
  2. lcryderman's Avatar
    I'm also having this problem as well, except that I'm not getting a notification that I'm disconnecting and I don't have to be out of range. It's just randomly disconnecting.
    I have the Samsung Gear 2.
    04-21-2015 04:19 PM
  3. Stermilio's Avatar
    Have anyone had any luck? Samsung gear 2 neo and still have the same problem. Tried everything from factory reset to uninstalling etc...
    Samsung gear manager version 2.2.15022599
    04-27-2015 10:38 AM
  1. Replies: 4
    Last Post: 04-30-2015, 10:46 PM
  2. Replies: 1
    Last Post: 04-20-2015, 01:45 AM
  3. Auto Brightness keeps unchekcing itself
    By larryg in forum Samsung Galaxy S6
    Last Post: 04-19-2015, 05:34 PM
  4. Replies: 1
    Last Post: 04-19-2015, 03:29 PM
  5. Why My Samsung Galaxy Star Is Not Rooting With ODin?
    Last Post: 04-19-2015, 10:56 AM
