1. AC Question's Avatar
    i have the samsung galaxy grand prime and i deleted to somethings to clear storage and now i can not make phone calls ..when i press on the icon it shut down and turns back on .
    06-08-2016 01:58 PM
  2. H3aTeRzz's Avatar
    Hi there!
    I'm afraid that you have deleted a system file, and the only way to fix that, is to do a factory reset of your device. Word of caution, never delete; if there is not option to "uninstall" then NEVER delete, unless you're 100% sure it a file that is not a file that will corrupt your system.
    06-08-2016 04:14 PM
  1. Replies: 3
    Last Post: 06-10-2016, 10:32 AM
  2. Replies: 1
    Last Post: 06-08-2016, 06:31 PM
  3. can anybody tell me app's name
    Last Post: 06-08-2016, 04:12 PM
  4. does the marshmallow update on tab s2 support themes ?
    Last Post: 06-08-2016, 02:51 PM
  5. Galaxy S7 Active - Is the screen Flat or Curved?
    By felloffthetruck in forum Samsung Galaxy S7
    Last Post: 06-08-2016, 01:57 PM
