I installed a custom recovery image entered it and then tried to install super su zip after installing the phone rebooted and then started crashing on the logo showing (set warranty bit kernel) and I went ahead to see a tutorial on how to fix and downloaded a stock Rom for j2 pro installed it and then the problem is that the phone cannot boot anymore when I switch it on I must connect it to a charger if I remove it . It switches off even recovery mode cannot load anymore ....please someone help me i don't know what to do it turns on and off continuously
