Calling and Internet (LTE/4G) not possible at the same time on Samsung J3 (2016)
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,519
4,659
113
Welcome to Android Central! I moved this from the Note 4 forum to the J Series forum.
Which carrier are you on? In order to have simultaneous voice and data, VoLTE has to be supported (and although this is supported by Verizon, AT&T, and T-Mobile, I believe Sprint still hasn't completely rolled it out in the US).
BenjaminRo
4
Thanks. You're welcome. I'm a O² subscriber. Is it a cellphone problem with the multiplexing J3 (2016) or is the problem on the side of the telephone company?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,519
4,659
113
Did you get your phone from O2, or did you bring it to O2 from somewhere else?
Look in the Settings>Mobile Networks menu and look for an option for VoLTE. It might be called various things, like Enhanced 4G, Advanced Calling, HD Voice, or others.
BenjaminRo
4
I bought it from Amazon and subscribed to O² later. All I have in it is 2G, 2G&3G, LTE/3G. Can I activate the extra feature somehow?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,519
4,659
113
That's not the menu option I'm thinking of -- it sounds like you're looking at the Preferred Network Type option. If you can't find the option I suggested, then the phone's firmware probably doesn't support VoLTE.
Cy3berOdyssey
