1. yulandop's Avatar
    I have an Asus TF700 Infinity, I can use any external device with this, hard drive, flash drive keyboard, etc.
    Can i use the Note in the same way?
    11-04-2013 02:37 PM
  2. yulandop's Avatar
    Yeah i think that is a good work around.
    Would have been nice to use an adapter on the Note 10.1 with a portable HD.
    For carrying around.
    11-04-2013 03:23 PM
  3. Cobravision's Avatar
    The OTG cable is only $1.43 shipped:
    http://www.amazon.com/dp/B00871Q5PI/...cUvbUpU3209645
    Should be able to add external storage with it.
    11-04-2013 07:10 PM
  4. sacerdos's Avatar
    I have a motorola otg cable, and I can say for myself that it doesn't work.
    This works:
    http://www.amazon.com/gp/product/B00...cUvbUpU3209719
    There is one caveat, however. The note doesn't recognize ntfs drives. It will say that a usb drive is present. But it will also say that there is nothing on the disk. A fat32 sdcatd is recognized fine.
    Btw, with the 5 pin to 11 pin adapter, with a microsd power supply, I can successfully connect it to my tv via hdmi.
    Sent from my SM-P600 using Tapatalk 4
    11-04-2013 07:25 PM
  5. Cobravision's Avatar
    My USB thumb drive works fine with the OTG cable I referred to on my S4 (I'll have my Note on Wednesday). But yes, you will need to format the drive to fat32 or exfat. Android cannot access ntfs, which is the default file system for WinXP and up.
    11-04-2013 08:10 PM
  1. Sony Xperia Z1 - Transferring my downloaded apps to sd card
    By weirdoRhaz89 in forum Sony Xperia Z1
    Last Post: 10-02-2014, 12:52 PM
  2. New Note 3 issue
    By Josh Easley in forum AT&T Samsung Galaxy Note 3
    Last Post: 11-20-2013, 11:45 PM
  3. Nexus 10 and SIM Card Adapter
    By MPBoulton in forum Google Nexus 10 Tablet
    Last Post: 11-06-2013, 03:36 PM
  4. Replies: 3
    Last Post: 11-05-2013, 07:12 PM
  5. S notes are locked when opening S notes from Note 3 on a Note 2
    By mouglie2 in forum T-Mobile Galaxy Note 2
    Last Post: 11-04-2013, 02:47 PM
