1. Acantha's Avatar
    I like to have an extra charger on hand, as they do break, eventually. The Note requires a special charger, and I'm not sure where to find it. Help!
    03-22-2015 03:56 PM
  2. monsieurms's Avatar
    You can get it from AMazon, Samsung, and here, I believe.
    Samsung 2A Adaptive Fast Charging Micro-USB Wall Charger - Android Wall Chargers - ShopAndroid
    The difference in the original Note charger is that it supports fast charging. Other 2a chargers will work--they just won't support the fast charge feature.
    03-22-2015 04:05 PM
  3. Acantha's Avatar
    It will say plugged in, but it won't charge on my phone charger.
    Thanks! I'll order one.
    03-24-2015 09:29 AM
  4. monsieurms's Avatar
    You may have been using something with a different rating?....but I have used non-adapative chargers on the Note 4 that are rated at 2.0 without any problem. Of course, I was using the Note 10.1 2014 charger for that purpose. It doesn't charge as fast AS adaptive charging, but it worked.
    03-27-2015 07:30 AM
  1. Replies: 3
    Last Post: 03-24-2015, 05:26 PM
  2. Replies: 1
    Last Post: 03-23-2015, 05:39 PM
  3. wireless charger for Nexus 6
    By Alfred Rillo in forum Google Nexus 6
    Last Post: 03-23-2015, 03:57 PM
  4. Why does my phone say charger not recognized charging deactivated?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 03-22-2015, 02:55 PM
  5. Why isn't my Samsung Tab 3 charger charging?
    By AC Question in forum Samsung Galaxy Tab 3
    Last Post: 03-21-2015, 05:43 PM
