1. Debberz's Avatar
    Hoping someone can help me with my galaxy note tab 10.1 2014 edition. My battery may say it's at 100% then I unplug it and bam! It may say 24% percent then. Most of the time if it's at 100% and I leave it plugged in then it may stay 100% while I'm on it. If I try to use it without being plugged in then I may only get a half hour of juice. And then if I plug it in and using it then it will not charge either. I was thinking it needed a new battery but have already spent 39 dollars for a diagnostic test then they sold me the plug I part of the charger that goes to the wall. It did not fix my problem. Has anyone had this problem or know what it might be? Thank you
    12-19-2015 07:50 AM
  2. Dale_M's Avatar
    Sounds if your battery may be bad, may have "capacity" issues..... If shop did diagnostic and then sold you a charger, you did not get full service from shop... Issue could also be bad charge cord or bad USB socket on tablet or also possible poor connection where battery plugs into mother board internally...... Suggest you bite the bullet and take it to a competent shop that specializes in tablets and such...
    Dale
    12-19-2015 10:32 AM
  3. Beut's Avatar
    Read this post
    http://forums.androidcentral.com/sam...ml#post4549435
    I'm pretty sure your battery connector needs to be re soldered, common defect of Samsung tablets.
    One temporary fix, put a thick piece of paper on top of your battery connector and secure with a tape. Direct pressure from the back cover will temporary close the crack on your battery connector.
    12-19-2015 02:05 PM
  1. Tapa Tapa Tapa ... for battery status
    By LinuxWeather in forum Pixel C
    Last Post: 05-04-2016, 07:47 PM
  2. charging case help
    By Sammiller88 in forum Samsung Galaxy Note 4 Accessories
    Last Post: 12-22-2015, 08:39 PM
  3. Note 3 not charging or staying charged :(
    By LindleyRDH in forum Samsung Galaxy Note 3
    Last Post: 12-19-2015, 05:44 PM
  4. help me with battery drain
    Last Post: 12-19-2015, 01:42 PM
  5. How do I remove a popup that says Your Battery Is Damaged By 4 Viruses?
    Last Post: 12-19-2015, 06:45 AM
