1. siroguma's Avatar
    Hello sorry if this has been asked before. I recently bought a refurbished note 10.1 2014 ed. from amazon. It works great but I can't seem to draw at all with it because the pen nib keeps pushing in when I draw. Is this not the official model? I compared pictures of my pen with the official one and it looks the same but I have to put so much effort into drawing just so that I can use the right amount of pressure to draw. I can't decide if I should return the note or complain to the seller...
    As long as I'm at it I appreciate if anyone has advice for good cases or screen protectors for the 10.1 2014 ed. Thanks in advance
    05-18-2016 02:33 AM
  2. Dale_M's Avatar
    Verify name "SAMSUNG" in on silver area at top of pen.... You may just need a new nib.... As my tablet came with 2 extra nibs...
    Might consider getting new pin and just move on instead of getting in "fight" with seller....
    https://www.fixez.com/samsung-galaxy...-A3RoCA2_w_wcB
    Dale
    05-19-2016 09:53 AM
  3. Beut's Avatar
    05-19-2016 09:02 PM
  4. Baby_Doc's Avatar
    Regarding the first reply and link from Dale M:
    This is the pen for the Note 3 phone. It will not fit correctly into the slot on the tablet, even though it will work on the screen. Be sure to order a SPEN specifically made for the Note 10.1 ( 2014 edition).
    There are many listed on Ebay and Amazon. Be sure it says OEM. Otherwise, again, it might not fit inside the tablet.
    05-20-2016 08:13 AM
  5. Beut's Avatar
    Actually it's not made for the Note 10.1 only. The S pen for Note Pro 12.2 is exactly the same, it fits both models with different screen sizes.
    I bought dozens of this S Pen for Galaxy Note Pro 12.2 SM-P905V from Verizon and Note Pro 12.2 SM-P900 Wifi version ; it's only $2.94 each
    it sits perfectly in the S Pen slot.
    Problems with S Pen - drawing is troublesome because pen nib won't stop pushing in?-s-pen.jpg
    High Quality Touch Stylus s Pen for Samsung Galaxy Note 10 1 P600 GFY | eBay
    05-20-2016 06:58 PM
  1. Replies: 1
    Last Post: 05-19-2016, 06:18 PM
  2. Replies: 1
    Last Post: 05-19-2016, 06:14 PM
  3. Replies: 1
    Last Post: 05-19-2016, 05:04 AM
  4. Replies: 1
    Last Post: 05-18-2016, 01:45 AM
