1. Moto0685's Avatar
    I recently replaced a USB port and in the setting it says it is not charging but yet it is by battery apps I have installed also the microphone does not work I have checked the connection and it is firmly secured to the USB power cable assymbly
    01-23-2017 09:24 AM
  2. DennisOS2's Avatar
    There others that are more expert than myself, but this sounds like it could be the motherboard solder joints on the battery connector. This is the connector that the battery charger plug mates with. There are six solder joints that can crack. It could be any one or more of the six joints. Usually when the tablet is apart for charging issues those solder joints should be re-soldered.
    04-06-2017 02:48 PM
  1. Replies: 1
    Last Post: 04-11-2017, 05:17 AM
  2. Display goes off and on while charging
    By ogdlow in forum Samsung Gear S2
    Last Post: 03-19-2017, 07:13 PM
  3. Battery life of Axon 7 screen shots plz
    By jeetu4444 in forum Axon 7 & Axon 7 mini
    Last Post: 01-28-2017, 08:39 PM
  4. Replies: 6
    Last Post: 01-23-2017, 02:37 PM
