1. snow685's Avatar
    Hello, I have something called primary dysgraphia. Taken from Wikipedia: Dysgraphia is a deficiency in the ability to write primarily in terms of handwriting, but also in terms of coherence. Dysgraphia is a transcription disability, meaning that it is a writing disorder associated with impaired handwriting, orthographic coding (orthography, the storing process of written words and processing the letters in those words), and finger sequencing (the movement of muscles required to write). This also effects my fine motor skills. I went to Best Buy and was told that i can take pictures of a work book (the stupid kind with fill in the blanks) and write and it will convert it to legible text. The sales associate said "You can take pictures and drag a text box and write and it will convert it to text." I cant find the option that allows me to edit the photo in a way where i can drag a text box over it and write. All i have is ps touch and paper editor. I tried setting the background in S notes to a picture but it didnt get the whole picture it cropped some out. It also didnt let me drag a text box where i wanted to. Can someone please help me with my issue?
    Many thanks ahead of time!
    09-30-2013 04:35 PM
  2. Ryandroid86's Avatar
    Samsung place an application called Optical reader on your device. This is what will do that for you.
    If it does not come with the application.
    You should be able to download it in the samsung app store
    09-30-2013 06:20 PM
  3. snow685's Avatar
    I looked on my tablet and on the app store, cant find "Optical reader."
    Where else could it be?
    09-30-2013 07:05 PM
  4. Ryandroid86's Avatar
    Try downloading Google goggles. I heard it can read documents.
    09-30-2013 09:28 PM
  5. oz123's Avatar
    snow685, you can do what you want, just use the menu shown in the attached screenshot.
    10-01-2013 03:48 AM
  1. AT&T Samsung Galaxy Note 3 64GB option
    By adam13141 in forum AT&T Samsung Galaxy Note 3
    Last Post: 10-16-2013, 08:50 PM
  2. what is the difference between the old note 10.1 vs 10.1 (2014)?
    By killer007 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 10-13-2013, 08:30 PM
  3. Replies: 11
    Last Post: 10-02-2013, 11:25 AM
  4. Writing issues samsung note 10.1
    By snow685 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 10-01-2013, 12:53 PM
  5. Just played with a demo Note 3 at AT & T store......
    By climb in forum Samsung Galaxy Note 3
    Last Post: 09-30-2013, 09:03 PM
