1. jeffmogil's Avatar
    In the last two days my phone has restarted on its own. This morning it has restarted every 10 minutes. Is this happening to anyone else?
    05-01-2020 07:32 AM
  2. mustang7757's Avatar
    Possible a app is causing this , try in safe mode see if it still happens but stay in it for good amount to test.
    05-01-2020 10:15 AM
  3. jeffmogil's Avatar
    Thanks, I uninstalled the last app(Hulu) I added, which coincides with the restarting issue.
    Hopefully that will work.
    05-01-2020 11:08 AM
  4. mustang7757's Avatar
    Ok , great, let's see if that was the one .
    05-01-2020 12:22 PM
  5. B. Diddy's Avatar
    If it keeps restarting, then boot into Safe Mode as mustang7757 suggested, to see if the problem is due to something you installed vs some problem with the system. https://www.t-mobile.com/support/dev...-galaxy-note10
    05-01-2020 12:34 PM
  6. blackhawkhot's Avatar
    Clear the system cache in the boot menu if you still are having trouble... especially if you haven't done so recently.
    05-01-2020 12:40 PM
  7. jeffmogil's Avatar
    Before I had a chance to try any of the suggestions, my note 10 plus went completely dead. I put the aim and as card in my old note 9. Now I'm debating what to do with my dead note 10 plus. All the Verizon stores around me are closed so do I try calling Verizon(that's a nightmare) or Samsung? Does anyone have any ideas? Thanks
    05-04-2020 06:23 AM
  8. jeffmogil's Avatar
    I meant Sim and SD cards
    05-04-2020 06:24 AM
  9. B. Diddy's Avatar
    What a bummer! Whom to call probably depends on how old the phone is. If you got it within the last month or so, start with Verizon, because it might end up being a more straightforward replacement process. If they say it's too late, then contact Samsung for warranty repair/replacement.
    blackhawkhot likes this.
    05-04-2020 10:37 AM
  10. blackhawkhot's Avatar
    Really does suck, and mars the experience
    Escalating it with Verizon might help if they don't do a straight replacement.
    Get all over on them like a cheap suit if need be.
    Their retainment dept or whatever they call it (AT&T, Customer Loyalty group) may be more helpful.
    Sales group as well. Different departments and/or individuals can alter the outcome greatly.
    Assertive training helps... consider this a lesson in it if the first call doesn't get it done easy.
    B. Diddy likes this.
    05-04-2020 11:12 AM
  11. blackhawkhot's Avatar
    Try another charger and cable... good luck
    05-04-2020 11:14 AM
  12. mustang7757's Avatar
    If you bought through carrier try then first to call otherwise get in touch with Samsung , either way your under warranty
    05-04-2020 11:16 AM
  1. Samsung Note 10+ and Note 10 May security patch is out.
    By jeetu4444 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 06-03-2020, 06:15 AM
  2. Replies: 14
    Last Post: 04-30-2020, 10:35 PM
  3. Why is my Ainol tablet keeps freezing at the Android startup screen?
    Last Post: 04-30-2020, 03:33 PM
  4. How do I delete the messenger home app from s10 plus
    Last Post: 04-30-2020, 01:54 PM
  5. New Zenpad 3s 10 Z500m won't update Android or firmware
    Last Post: 04-30-2020, 12:28 PM
