Wireless ear phones
nonie
1,568
9
38
Can anyone recommend any that work for talking and listening to music, audible. I use mainly around the house while doing house work, in sewing rm, etc. Anything under a $100,worth looking at. I have old ones that sound is good, but getting to where they don't hold a charge long.
You can find the first Galaxy Buds for under a 100 quid and they just got a fair good software update that apparently improved them a lot.
Jabra 65t you should be able to get as well under a 100 quid.
Aukey T10 or T21 are good too and a good bit under 100, more like 35-60
Thanks, I'll check these out.
I like the looks of the Anker Soundcore Liberty Air 2.
The literature on it sounds pretty good.
Anyone had one of these?
Or have opinion on it.
Get the Samsung Galaxy Buds, they're comfortable and stay put. Have them and wuv them.
The Buds Plus are out but there about $140; better battery life, audio Q and call Q. These are on my hit list...
You'll want to download the Samsung Wearables app to control them proper and update them if you go the way.
Anker makes great products too, you won't go wrong with those either, I haven't tried them myself but they do get good reviews.
These are over $100.00 aren't they?
I don't want to spend a bunch. Lol. Just want them good. Lol, would like to wear one at a time, if I want to.
Not sure if you're in the US or not, but Memorial Day sales are coming up. If you find a pair you're interested in that aren't too far out of your price range give them another look around Memorial Day weekend. They may come down to a more reasonable price.
https://forums.androidcentral.com/e...%2F6347460.p%3FskuId%3D6347460&token=bJInw2kV
Edit links not working
Samsung Buds
BestBuy has them for $110
Jabra 65t $99
Yes in US. Good idea. Thanks
TheGreatApe00
