1. bgbagz's Avatar
    So I read and article on https://www.t-mobile.com/news/rcs-with-Google
    My question is, will RCS be Installed. On the Factory unlocked 10 plus Model number
    SM-N975U flashed with T Mobile firmware. Cause as I understand the article, it should be there.... Looking at my settings I do not see anything indicating my messaging App has RCS capabilities.
    Thoughts....
    05-28-2020 07:58 AM
  2. mustang7757's Avatar
    SM-N975U1 which is unlocked version with TMobile sim no RCS with Samsung message app , SM-N975U carrier version with TMO yes RCS.
    Can you flash SM-N975U1 to SM-N975U definitely
    05-28-2020 08:07 AM
  3. wbcolon's Avatar
    I have an unlocked n10+ on t mobile and I have rcs with the stock Samsung app. You have to have google duo installed for the features to show up.
    JHStewart1023 likes this.
    05-28-2020 06:33 PM
  4. bgbagz's Avatar
    I have Google Duo... Use it everyday.... But nothing that indicates RCS
    05-28-2020 07:49 PM
  5. wbcolon's Avatar
    There’s options to turn new features on.
    05-28-2020 07:53 PM
  6. mustang7757's Avatar
    You have model number SM-N975U1?
    wbcolon likes this.
    05-28-2020 08:33 PM
  7. wbcolon's Avatar
    Yes that’s the model I have.
    05-28-2020 08:35 PM
  8. mustang7757's Avatar
    You have rcs on stock Samsung message app?
    05-28-2020 08:42 PM
  9. Guru's Avatar
    Download google messages as not only is it MUCH better than the samsung app it will work correctly with Android Auto and RCS properly. As for getting the Samsung app to work have you force stopped it and rebooted phone?
    05-29-2020 12:47 PM
  10. mustang7757's Avatar
    Samsung app on the unlocked version doesn't have rcs
    05-29-2020 12:56 PM
  11. bgbagz's Avatar
    Which is crazy... Unlocked with Tmo firm should have it and or get it
    05-31-2020 09:11 AM
  12. mustang7757's Avatar
    Oh I agree
    Stuck with Google message for now
    05-31-2020 11:37 AM
  1. Instagram not installing on my Galaxy Note 10+
    By Lynnzerr in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 05-28-2020, 12:23 PM
  2. S20 plus outsold all other S20 models-3.5 million units
    By Notefan161 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 05-28-2020, 08:35 AM
  3. Replies: 2
    Last Post: 05-28-2020, 12:36 AM
  4. Is there a delay in ending call using note 8 when pressing end button
    Last Post: 05-27-2020, 08:58 PM
