Dell Technologies Cyber Savings Event - Up to 45% off
  1. cjtkd's Avatar
    So I've been using my phone a lot this past couple of months so I've not paid the slightest bit of attention to battery life. By chance yesterday I thought it seemed to be chomping through battery pretty quick so I fully charged today and took this screen grab just now.
    I'm not all that clued up on how android is reporting use now, does this seem 'normal or withing expected range?
    Thanks in advance
    Attached Thumbnails Does this battery consumption look right?-screenshot_20200605-145720_device-care.jpg
    06-05-2020 09:10 AM
  2. the_boon's Avatar
    If you use the Facebook app alot, I would consider disabling it and using Facebook Lite instead if you're okay with the Lite one's more basic look.
    06-05-2020 09:30 AM
  3. msm0511's Avatar
    Or just use in the browser. FB is definitely a battery hog.
    Ruben Ocasio and gendo667 like this.
    06-05-2020 09:32 AM
  4. cjtkd's Avatar
    Sadly I use it a lot for work, however I don't remember it being this hungry in the past? I tried reinstalling but still reporting like this. Is this normal?
    Trust me to look lol. I should have stayed oblivious
    06-05-2020 10:08 AM
  5. B. Diddy's Avatar
    Is your cell signal usually like that, or is it worse in a particular location? Poor cell signal can contribute to battery drain.
    06-05-2020 12:36 PM
  6. Ruben Ocasio's Avatar
    Exactly how i use Facebook.
    06-05-2020 02:26 PM
  7. cjtkd's Avatar
    Like this when I'm at home, however this isn't a new thing and this change in battery drain is. I'm not sure if it relates to the last OS update?
    06-05-2020 02:53 PM
  8. the_boon's Avatar
    I feel like the browser would be more of a battery hog than FB Lite.
    Besides with the latter you can have notifications
    06-05-2020 03:32 PM
  9. cjtkd's Avatar
    Could anyone else post a screen shot of how their Facebook app is behaving? Is it normal to have so much background use?
    06-05-2020 04:16 PM
  10. mustang7757's Avatar
    Thanks in advance
    For Facebook you can turn off background activity , and put app to sleep in device care
    06-05-2020 04:39 PM
  11. cjtkd's Avatar
    Sure, however I've never had to do that in the past so I wondered why now?
    06-05-2020 04:41 PM
  12. mustang7757's Avatar
    You using it more often?
    06-05-2020 04:47 PM
  13. cjtkd's Avatar
    I wouldn't say so l, no hmm
    06-05-2020 05:24 PM
  14. mustang7757's Avatar
    Possible update to it changed its behavior
    06-05-2020 05:32 PM
  15. Mike Dee's Avatar
    I heard your better half gave you an update that changed your behavior.
    06-05-2020 05:43 PM
  16. mustang7757's Avatar
    Those are just rumors
    06-05-2020 05:45 PM
  17. BigMosely's Avatar
    It appears neither of those options support Gifs and what's the point of FB without annoying people with Gifs.
    06-05-2020 09:45 PM
  18. TMavC5's Avatar
    Uninstall FB and use a browser instead.
    Laura Knotek likes this.
    06-07-2020 01:25 PM
  19. Bodestone's Avatar
    People are sending a shed load more messages recently so your sync will be more active using both antenna and CPU power on the app. Delete all the people talking tosh.
    06-08-2020 03:46 PM
  20. Ruben Ocasio's Avatar
    Battery life here is outstanding since i preordered the Note10 Plus on release day still getting awesome Battery life.
    Does this battery consumption look right?-screenshot_20200609-090907_gsam-battery-monitor-pro.jpg
    Does this battery consumption look right?-screenshot_20200609-090917_device-care.jpg
    06-09-2020 10:12 AM
  21. Bodestone's Avatar
    My batery is great also but I have no social media apps installed.
    06-09-2020 04:40 PM
  22. ralfyguy's Avatar
    How did you get a custom background in this screen?
Name:	Screenshot_20200609-090907_GSam Battery Monitor Pro.jpg
    06-09-2020 06:21 PM
  23. Ruben Ocasio's Avatar
    Hex Pro
    06-09-2020 07:19 PM
  24. Ruben Ocasio's Avatar
    Does add it in other places. And you can put any custom wallpapers.
    Does this battery consumption look right?-screenshot_20200609-181927_messages.jpg
    Does this battery consumption look right?-screenshot_20200609-181958_settings.jpg
    Does this battery consumption look right?-screenshot_20200609-182011_settings.jpg
    06-09-2020 07:22 PM
  1. Replies: 5
    Last Post: 06-08-2020, 08:14 PM
  2. Replies: 1
    Last Post: 06-07-2020, 11:35 PM
  3. Why does the screen light go off when making outgoing calls?
    Last Post: 06-07-2020, 11:32 PM
  4. Weird Idle Battery Consumption
    By momobordz in forum Hardware Hideaway
    Last Post: 06-07-2020, 08:54 PM
  5. Replies: 3
    Last Post: 06-07-2020, 11:11 AM
