1. eltorotx's Avatar
    I want to purchase a note 10 plus 5g verizon version and I was wondering if anyone here has tried using an unlocked verizon 5g on xfinity mobile? The amount I save a month on this service is great and although they now support 5g and even sell the s20 ultra 5g, they don't sell the note 10 plus 5g. Now verizon does and xfinity mobile uses Verizon for its service. Will this device work? If it does, will the 5g work as well? Where I live at 5g is active. Also forgot to mention that I can buy a 5g 10 plus cheaper than buying a 10 plus through xfinity which is why I'm interested. TIA!
    06-06-2020 11:29 PM
  2. BergerKing's Avatar
    While I don't know the answer to the question, I titled your thread to better convey the question you were trying to ask. I hope this helps you get the information you need!
    06-07-2020 12:06 AM
  3. eltorotx's Avatar
    Thank you so much for your help!
    06-07-2020 12:14 AM
  4. jamjordan's Avatar
    I work for Comcast and yes you can bring a phone over. The mobile network is backed by Verizon.
    06-07-2020 05:53 AM
  5. eltorotx's Avatar
    Does it matter which model? I've tried purchasing a note 10 plus 5g Verizon, and the seller checked the IMEI and said Xfinity won't take it. It left me confused because Xfinity sells the s20 ultra 5g so I figured the note 10 plus 5g from Verizon would work. Have you verified if the 5g variant works?
    So if I buy any note 10 plus that's a Verizon version, it should work, right? Xfinity plus BYOD page confuses me because it seems to reject every IMEI I input that's a note 10 plus.
    06-07-2020 11:37 PM
  6. buzzy3970's Avatar
    Same here. Curiously I checked the imeis that I'm using on Verizon(not Verizon variants) and all of them said they don't work. Could be like Verizons imei checker as my S20 Ultra supposedly doesn't work, but I've been using it for over 2 months without any issues.
    06-08-2020 12:29 AM
  7. eltorotx's Avatar
    What carrier your s20 ultra from?
    06-09-2020 05:53 PM
  8. eltorotx's Avatar
    06-09-2020 05:54 PM
  9. buzzy3970's Avatar
    T-mobile. Use to not register on verizons site as compatible but curiously I checked yesterday and it finally reads my imei and says things are go although I've been using it for months with no issues
    06-09-2020 09:10 PM
  10. buzzy3970's Avatar
    I would say yes. My note 10 plus that I purchased completely unlocked for Samsung
    says the same. I think the imei checker is just not working.
    06-09-2020 09:12 PM
  11. Mike Dee's Avatar
    06-09-2020 09:18 PM
  12. buzzy3970's Avatar
    If you've been using unlocked Ultra on Verizon there shouldn't be issues
    The issues arised when I tried to get a 5G sim card activated because the system didn't recognize my imei it couldn't be activated. Tried a lot for weeks and finally got a friend with a 5G phone(not Verizon) were imei was recognized by the system and had sim activated. Popped in my phone and begin using phone again like normal.
    06-09-2020 09:22 PM
  1. Trying to delete .profig.os
    Last Post: 06-06-2020, 06:26 PM
  2. My phone says the weather widget is on my home page, but I can't see it.
    Last Post: 06-06-2020, 06:23 PM
  3. Is someone using com.wssyncmldm to gain access to my phone
    Last Post: 06-06-2020, 06:07 PM
  4. What is Font Server in Notification channel 3?
    By LillyFlower in forum General Help and How To
    Last Post: 06-06-2020, 05:41 PM
  5. Network Cell Info Question
    Last Post: 06-06-2020, 04:36 PM
