How do I activate Auto Hotspot on my Samsung devices?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,518
4,661
113
Are you certain your wireless plan allows for hotspot usage? Which carrier do you have, and what country are you in?
L0n3N1nja
3,629
4
If you're in the US and have a carrier branded phone it's likely the feature was removed. I know Verizon is notorious for modifying Samsungs default features like this. I could easily see them removing this to prevent people from going over on data by accident.
Hghlndr
378
19
18
OP I'm with Verizon and my plan includes Mobile Hotspot.
Am on Android 10 using a Note10+. As was stated may be a carrier suppression (and you might use an app like: QuickShortCutMaker to find it), though i found it under Connections/ MobileHotspot&Tethering/ MobileHotspot (long press to see sub menu)/ Select AutoHotspot
And, do check out the afore mentioned app if Auto Hotspot is not there in the settings! Good Luck
Laura Knotek
Moderator Captain
Moderator
Jan 8, 2011
11,773
3,985
113
I have Verizon, and mobile hotspot is available on my plan.
Adam Frix
1,095
Jan
