07-13-2020 11:24 AM
30 12
tools
  1. Bat Batmar's Avatar
    does anyone know how auto hotspot work? I'd like to use my Samsung galaxy tab s4 with note 10 auto hotspot....thanks
    06-25-2020 04:32 AM
  2. Galactic Zoo's Avatar
    06-25-2020 04:42 AM
  3. Bat Batmar's Avatar
    Thank you but sadly it doesn't work....it doesn't show auto hotspot network...
    06-25-2020 06:09 AM
  4. B. Diddy's Avatar
    Are you certain your wireless plan allows for hotspot usage? Which carrier do you have, and what country are you in?
    Laura Knotek and buzzy3970 like this.
    06-25-2020 12:21 PM
  5. L0n3N1nja's Avatar
    If you're in the US and have a carrier branded phone it's likely the feature was removed. I know Verizon is notorious for modifying Samsungs default features like this. I could easily see them removing this to prevent people from going over on data by accident.
    06-25-2020 12:49 PM
  6. Bat Batmar's Avatar
    Maybe does it need Android 10? On my tablet I still have 9....
    06-25-2020 01:19 PM
  7. L0n3N1nja's Avatar
    Based on the link shared above the feature is enabled on the phone, tablet software version would have no effect on that.
    06-25-2020 01:22 PM
  8. L0n3N1nja's Avatar
    Are you logged in with the same Samsung account on both devices? That might be a factor.
    06-25-2020 01:23 PM
  9. Bat Batmar's Avatar
    Yes I am....and unlocked phone....italy
    06-25-2020 02:14 PM
  10. Hghlndr's Avatar
    OP I'm with Verizon and my plan includes Mobile Hotspot.
    Am on Android 10 using a Note10+. As was stated may be a carrier suppression (and you might use an app like: QuickShortCutMaker to find it), though i found it under Connections/ MobileHotspot&Tethering/ MobileHotspot (long press to see sub menu)/ Select AutoHotspot
    And, do check out the afore mentioned app if Auto Hotspot is not there in the settings! Good Luck
    Laura Knotek likes this.
    06-26-2020 02:23 AM
  11. Laura Knotek's Avatar
    I have Verizon, and mobile hotspot is available on my plan.
    06-26-2020 02:59 AM
  12. Adam Frix's Avatar
    I have Verizon, and mobile hotspot is available on my plan. [IMG=1440x3040]https://uploads.tapatalk-cdn.com/20200626/91ac2ff0474ce5700b2d3a6c02c9d548.jpg[/url]
    The question isn't hotspot. The question is Auto Hotspot. Someone thought that maybe allowing devices invisibly and without thought or action to use the phone's hotspot was something Verizon didn't want due to data limits.
    The above link is for Australia. The US information is here:
    https://forums.androidcentral.com/e?...token=l1INoZnE
    06-26-2020 08:09 AM
  13. cardboard60's Avatar
    Forget auto hotspot.
    Pull your screen down from the top.
    Touch hotspot to turn it on.
    Do the same thing to turn it off.
    06-26-2020 09:58 AM
  14. Mike Dee's Avatar
    It shows on my Unlocked S20 Ultra
    06-26-2020 11:18 AM
  15. Bat Batmar's Avatar
    I mean....it doesn't show auto hotspot network on my galaxy tab s4....it shows on my note 10+.....
    06-26-2020 12:18 PM
  16. Mike Dee's Avatar
    Your tablet wouldn't have a hotspot unless you have a tablet that connects to cellular. The tablet has to be signed in to your Samsung account.
    06-26-2020 02:33 PM
  17. Bat Batmar's Avatar
    It is....same samsung account...I want to use auto hotspot feature with my tablet that is Wi-Fi only...
    06-26-2020 02:35 PM
  18. Super Dave426's Avatar
    When you scan for wifi networks on your tablet do you see your phone? That's where you connect, password is usually your phone number.
    06-27-2020 07:20 AM
  19. Mike Dee's Avatar
    The issue doesn't seem to be connecting to the hotspot. The OP wants auto hotspot to work.
    06-27-2020 08:46 AM
  20. cardboard60's Avatar
    Who would want to leave hotspot on a phone on.
    Really
    06-27-2020 08:54 AM
  21. Mike Dee's Avatar
    Really
    I think you misunderstand the intent
    06-27-2020 09:15 AM
  22. cardboard60's Avatar
    Explain it to me
    06-27-2020 09:20 AM
  23. Mike Dee's Avatar
    Explain it to me
    If I understood correctly, the OP wants to auto connect his tablet to his phones hotspot. There's nothing wrong with that and there's no real harm in wanting to keep auto hotspot active.
    06-27-2020 09:45 AM
  24. bennett22's Avatar
    i've used this before on my at&t note 10+, its a great feature. this is how i tuned it on=settings, connections, mobile hotspot and tethering, click on mobile hotspot even if its off, scroll to the bottom and turn on auto hotspot
    06-28-2020 12:21 PM
  25. buzzy3970's Avatar
    Once it's setup you can activate it from the phone or tablet. It's fairly easy.
    06-28-2020 09:01 PM
30 12
  1. Volume changing on its own?
    By atremorer in forum Samsung Galaxy S10 & S10+
    Last Post: 06-28-2020, 09:43 AM
  2. I forgot my kids lock and device got locked, how do I unlock it?
    Last Post: 06-25-2020, 12:23 PM
  3. Samsung Galaxy Tab S6 SM-T865 - No YouTube icon?
    By Android Central Question in forum Samsung Galaxy Tab S6
    Last Post: 06-25-2020, 12:13 PM
  4. Samsung Galaxy Tab S6 SM-T865 - No YouTube icon?
    Last Post: 06-25-2020, 05:05 AM
