    I set up the camera to take pictures of birds visiting the bird feeder using a remote control while staying out of sight. I have set the screen to stay awake. But the camera shuts off after about 3 minutes even though the screen stays on. How do I keep the camera to stay on?
    07-12-2020 04:39 PM
  2. mustang7757's Avatar
    Maybe if you use it in video will stay longer and can take a picture also.
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.https://forums.androidcentral.com/sh...d.php?t=409154
    07-12-2020 05:14 PM
  3. mustang7757's Avatar
    [Moved to note 10 forums for specific traffic]
    07-12-2020 05:14 PM
  4. ManiacJoe's Avatar
    Most cameras will auto-close if you are not interacting with them because they eat up a lot of battery power due to the direct feed to the screen.
    If your remote does not allow for some type of interaction with the camera other than to release the shutter, you are probably out of luck.
    07-12-2020 09:33 PM
  1. "No SIM Card" error on my Note 4...
    By swansswansswans in forum Samsung Galaxy Note 4
    Last Post: 08-01-2020, 03:28 PM
  2. I forgot my pattern for the hide app gesture on my TECNO Pouvoir 3 Air.
    Last Post: 07-13-2020, 06:45 AM
  3. How does FaceTime work on an iPhone?
    Last Post: 07-12-2020, 07:19 PM
  4. My phone HTC desire eye when I connect usb to laptop its not showing anything.
    Last Post: 07-12-2020, 03:47 PM
