Save big + get 3 months free! Sign up for ExpressVPN today
  1. cjtkd's Avatar
    Has anyone else had anything get inside their camera glass before? There's something on the glass of my Note 10+, it doesn't look to be a scratch on the outside, its too 'white' can't be felt at all.
    It doesn't appear to be effecting photos, just a tad annoying.
    07-21-2020 05:18 AM
  2. VidJunky's Avatar
    Welcome to Android Central. To reply to this thread and receive notifications when others leave comments please register an account. This link will help you do that... https://forums.androidcentral.com/as...-new-post.html
    The Note should be IP68, I believe, so if there is something behind the glass I would think that might qualify as a warranty issue, if your warranty is still valid. If it isn't affecting your photos you're lucky. If you wanted to test if your device has openings that could have caused this you could insert the straw end of can of compressed air in your S-Pen hole and blow around, see if you can affect the debris. If you can your IP rating is already gone so you could try to have it fixed. You could take it to someplace like UBreakIFix. They tell you up front that they don't warranty the IP rating but if it's already gone having them look at it should seal your device, maybe better than it is. Warranty or insurance would probably both recommend the same course of action and save you a few bucks, maybe.
    Is your phone a back pocket rider? Flexing and being warmed by your body heat multiple times a day can take its toll. I wouldn't imagine the same from a front pocket rider or in a bag of some kind.
    Let us know what your thinking and plan to do.
    07-21-2020 06:14 AM
  3. mustang7757's Avatar
    07-21-2020 10:39 AM
  4. B. Diddy's Avatar
    Duplicate threads merged, original post owner changed from guest to member.
    07-21-2020 08:41 PM
  5. cjtkd's Avatar
    Heres some images. I had fo use my ipad to take them so please keep that in mind. Its inside the middle lens. A scratch of that size would easily be noticeable with the end of my thumbnail, nothing there. When held at an angle a light source, the reflection can be seen on top of surface above the speck.
    Attached Thumbnails Gap between glass and camera unit?-screenshot_20200722-200250_gallery.jpg   Gap between glass and camera unit?-screenshot_20200722-200235_gallery.jpg   Gap between glass and camera unit?-screenshot_20200722-200226_gallery.jpg
    07-22-2020 02:07 PM
  6. mustang7757's Avatar
    This what your referring to?
    07-22-2020 02:31 PM
  7. cjtkd's Avatar
    Middle lens
    07-22-2020 03:08 PM
  8. mustang7757's Avatar
    07-22-2020 03:11 PM
  9. cjtkd's Avatar
    Naw, its deffo a bit of something like a hair or fiber. It's waaaaay too small to be a component
    07-22-2020 03:13 PM
  10. L0n3N1nja's Avatar
    It's not directly in front of the camera it's why it doesn't impact images taken with the camera.
    It's hard to know what it is, but it shouldn't be dust that got in after you bought it because the phone is dust/water resistant with its I68 rating. Possible an impact caused a mark within the glass but wasn't strong enough to cause an actual crack. That would only be a guess, I really don't know.
    07-22-2020 04:52 PM
  11. mustang7757's Avatar
    Is the glass chipped?
    07-22-2020 05:30 PM
  12. VidJunky's Avatar
    That gap you're pointing to seems a bit small for something of that size to have made it through. I'm still thinking it got in through your S-Pen dock.
    07-22-2020 08:15 PM
  13. cjtkd's Avatar
    I guess the lucky things are.
    1. It still works fine
    2. It's a business handset so whilst annoying, it's a work tool rather than a personal item (stops me stressing lol)
    3. It is still under warranty so I guess I could take it into a store if it bugs me a few weeks down the line.
    07-23-2020 01:43 AM
  14. cjtkd's Avatar
    If it is, its on the inside as it can't be felt
    07-23-2020 01:48 AM
  15. cjtkd's Avatar
    Could be I guess. Its been in a case since day one. Its only had one significant drop, but that was onto a matted floor. I've noticed that these things seem to mark up really easy compared to my other Samsung handsets I've had (Note 4, S7 Edge, S9+) the frame managed to get a decent scratch wilst the case and the screen picked up a micro scratch from my pocket.
    I'm a careful user too so its all rather frustrating.
    07-23-2020 01:48 AM
  16. mustang7757's Avatar
    Gotcha
    Strange !
    07-23-2020 01:57 AM
  1. Note 20 Ultra specs, (Europe) and official marketing pics!
    By LilSweetLin in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 07-26-2020, 05:49 PM
  2. Hi, Newbie here! I have a Samsung S10+ and wonna get into photography with it...
    By Android Central Question in forum Samsung Galaxy S10 & S10+
    Last Post: 07-23-2020, 12:01 PM
  3. Backup and restore to new phone.
    Last Post: 07-21-2020, 08:06 PM
  4. Hi, Newbie here! I have a Samsung S10+ and wonna get into photography with it...
    Last Post: 07-21-2020, 12:30 PM
  5. Dust inside camera glass?
    By cjtkd in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 07-21-2020, 05:22 AM
