1. kma581's Avatar
    Does the note 10 plus supposed to have super fast charging.
    07-22-2020 10:18 AM
  2. j_hansen's Avatar
    Yes
    07-22-2020 10:26 AM
  3. Mike Dee's Avatar
    Yes but there no real advantage to the 45 watt over the 25 watt charger as far as total charge time, especially when it's 50 dollars for the 45 watt. The 45 watt charger has better results on the S20 Ultra but it's still not worth buying it for most people.
    Nostromo79 likes this.
    07-22-2020 10:44 AM
  4. kma581's Avatar
    Mine never says super fast charging from the time I bought it. I'm using the charger that came with it. I'm just wondering why mine doesn't.?
    07-22-2020 12:19 PM
  5. Mike Dee's Avatar
    You need the 45 watt charger accessory but don't waste your money.
    07-22-2020 12:34 PM
  6. mustang7757's Avatar
    You look in device care if the option is toggle on ?Does Note 10+ have super fast charging?-screenshot_20200722-133538_device-20care.jpg
    07-22-2020 12:36 PM
  7. Mike Dee's Avatar
    You look in device care if the option is toggle on ?Click image for larger version.
    Super fast charging is not possible with the supplied charger and it won't show unless it's triggered by the 45 watt charger.
    07-22-2020 12:42 PM
  8. mustang7757's Avatar
    Yeah super fast need the 45w
    07-22-2020 12:43 PM
  9. kma581's Avatar
    Then why does the brick say super fast charging and when my wife plugs her s20 plus into my charger her phone says super fast charging. I don't even have a toggle in settings to turn it on like hers does.
    07-22-2020 12:47 PM
  10. j_hansen's Avatar
    My Note 10 plus 5G Exynos doesn't say Super Fast Charging just Fast Charging, that's with the 45W charger and the cable it came with.
    I was under the impression that the fast & super fast was between the 15w and 25w but that *Super* got dropped and that it is just either *Charging* or *Fast Charging*
    07-22-2020 01:02 PM
  11. Golfdriver97's Avatar
    I seem to recall a charging slowly title too. My Pixel would say that when I plugged it into my PC.
    07-22-2020 01:13 PM
  12. evohicks's Avatar
    The Note 10+ is pretty quick charging using the supplied charger on fast charge, the P40 Pro I have been using does say Superfast charging but that is charging at 40 Watts from the standard included charger.
    07-22-2020 02:45 PM
  13. Mike Dee's Avatar
    Both bricks say super fast charger and both will display Super fast on the S20 plus but the 45 watt is mostly faster on the front end of the charging cycle compared to the 25 watt charger especially on the S20 Ultra. In reality, Super fast is just a term and it doesn't tell you how fast it's actually charging.
    On the Note 10 plus they removed the Super fast toggle during an update without an explanation.
    https://us.community.samsung.com/t5/...p/td-p/1074993
    I have the S20 Ultra and the Note 10 plus. The Note 10 plus does not say Super fast any longer but it used to. Whether or not the 45 watt charger still makes a difference remains to be seen and I would have to time the device from zero twice which I'm not willing to do because it's bad for the battery. The difference from zero to full according to all reviews I've seen lists it maybe at an 8 minute difference. In my opinion the Note 10 plus charges pretty quickly without the 45 watt charger. I only bought it for the S20 Ultra where it has a bigger advantage due battery size and I purchased it with my Samsung credit during pre-order.
    j_hansen likes this.
    07-22-2020 06:08 PM
  14. j_hansen's Avatar
    I didn't know about the blue and white coloured circles, I do get blue for fast charging from both the Samsung 45W and also an Aukey 27W charger, plugging into a multiplug hub I have I get the white circle.
    07-23-2020 03:19 AM
  1. Replies: 4
    Last Post: 07-22-2020, 06:26 PM
  2. Replies: 4
    Last Post: 07-22-2020, 03:12 PM
  3. Replies: 3
    Last Post: 07-22-2020, 12:31 PM
  4. Replies: 1
    Last Post: 07-22-2020, 09:22 AM
  5. Encrypt does not encrypt SD card?
    By jmsnyc in forum Samsung Galaxy S8 & S8+
    Last Post: 07-21-2020, 10:39 PM
