1. raf66's Avatar
    Hi all. I have a N10+ 5G (Verizon) and my city has some 5G areas that I can't seem to find while in those locations but others with 5G phones can (I saw the 5G designation on their phone). When I look online at the settings other folks have on their 5G phones, I notice that my settings under "Mobile Network" don't look the same as there is no 5G setting under my "Network Mode". A screenshot is below.
    Any guidance would be greatly appreciated.
    11-14-2020 04:14 PM
  2. Mike Dee's Avatar
    There is no 5G special setting on Verizon. It's possible you need an update to receive 5G
    11-14-2020 04:19 PM
  3. raf66's Avatar
    Thanks Mike Dee. I'll check to see if I have a Verizon update.
    11-14-2020 05:35 PM
  4. raf66's Avatar
    No updates that I can find on the carrier (Verizon) side. I'm at a loss as to why my 5G enabled phone won't connect to available 5G networks. Frustrating.
    11-24-2020 07:52 PM
  5. mustang7757's Avatar
    Hi, how old your sim ? You can try resetting your network, go settings >general management >reset >reset network.
    11-24-2020 08:39 PM
  6. Mike Dee's Avatar
    Have you contacted Verizon?
    If you are referring to Nationwide 5G it might not be available for your device. According to the link below your device only supports UltraWide band 5G. I would call Verizon to confirm.
    https://community.verizonwireless.co...ng/m-p/1188115
    11-24-2020 10:45 PM
  7. raf66's Avatar
    Thanks for the link, Mike Dee. It appears I'm one of many VZW customers with this specific issue, and it seems as though relief is not on the horizon.
    12-18-2020 10:52 AM
  1. How to find a site's URL
    By William Hale3 in forum Ask a Question
    Last Post: 11-18-2020, 08:39 PM
  2. Another new phone choice thread, help!
    By Dagr in forum Buyers Guides
    Last Post: 11-15-2020, 07:54 AM
  3. Replies: 5
    Last Post: 11-14-2020, 11:53 AM
  4. Another new phone choice thread, help!
    By Dagr in forum Ask a Question
    Last Post: 11-14-2020, 09:20 AM
  5. Settings cards light gray and not dark .
    By frederickdawg in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 11-14-2020, 01:49 AM
