If that apk not installing then you'll need rootYes of course. The galaxy S5 has a special animated weather widget. I found the widget apk and daemon for galaxy S5 and my question Is there any method to install it on note 10+.
I found this link. I don't know if this works with note 10+
https://www.droidviews.com/install-galaxy-s5-accuweather-widget-galaxy-s4-galaxy-note-3/
Thank you once again
It's a widget you download from play store and drag it to your home screen from widget list , see if you like itCan you explain more the steps.
Yes not as secure , but if this first time diving into root, I would stay away.explanation about the root process and the apk installation. Is it dangerous for the device
Your welcome, if I run into anything else I'll keep u posted here .I tried it but the widget 4*2 shows only the time on the home screen (without picture). Thank you for your help. Very appreciated
