    How to end a call on Note 10 plus with android 10 using the power button. It was working before the upgrade to android 10
    12-29-2020 03:45 AM
  2. Ranjen617's Avatar
    Go into your phone, open up settings where the three dots are. You should be in call settings at this point, then go down to where it says, "Answering and making calls." Open that and you'll see it under there.
    Attached Thumbnails How to end a call on Note 10 plus with android 10 using the power button-14342.jpg
    B. Diddy likes this.
    12-29-2020 07:23 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    01-04-2021 10:21 PM
  1. Rooted my Pixel 3a, now I want to install android again - is that possible?
    By Android Central Question in forum Google Pixel 3a & Pixel 3a XL
    Last Post: 01-04-2021, 10:26 PM
  2. Is there a USB dongle that can run Android Auto with Spotify.
    Last Post: 01-03-2021, 07:12 AM
  3. White noise emitting from earpiece on handset
    By frederickdawg in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 12-29-2020, 10:42 PM
  4. When you turn off your phone does it go on home screen?
    Last Post: 12-29-2020, 12:39 AM
  5. Anyone RSVP to pre-order the S21?
    By Rose4uKY in forum Samsung Galaxy S10 & S10+
    Last Post: 12-28-2020, 11:18 PM
