1. jtfwTX's Avatar
    Happy New Year All!
    I have a tmobile unlocked Note10+5g version. When I check the quick panel settings and fully explore it, there is no icon/option for the built in screen recorder? I can search settings and see options like video size, sound options, etc but no way to enable it.
    I don't know if I could have somehow disabled it accidentally. Could it be removed b/c of a work security policy with their outlook email app (it has device admin access)? So I disabled that device admin option, restarted the phone, and the option is still not there.
    I don't know what to do.
    Could I manually enable it with an adb command? But I shouldn't have to do that, right? I really really don't want to factory reset it since I've tested a 3rd party app which works, but very disappointed I don't have the built in Samsung option right now.
    Any help from the community of experts is greatly appreciated! Thank you.
    01-01-2021 12:28 PM
  2. mustang7757's Avatar
    Hi, you double check the pull down notification panel to see maybe add as a toggle?
    jtfwTX likes this.
    01-01-2021 12:48 PM
  3. jtfwTX's Avatar
    Good grief. I double checked like you suggested. Nothing at the end of the screens to add. But I guess I finally noticed the options to add are at the TOP of the screen. I just saw it sitting there. Resolved and it works . Ugh. Sorry for the newbie mistake even though I thought i was closer to an android jedi
    mustang7757, kct1975 and B. Diddy like this.
    01-01-2021 02:04 PM
  4. mustang7757's Avatar
    Good grief. I double checked like you suggested. Nothing at the end of the screens to add. But I guess I finally noticed the options to add are at the TOP of the screen. I just saw it sitting there. Resolved and it works . Ugh. Sorry for the newbie mistake even though I thought i was closer to an android jedi ������������
    Thats great
    No problem Your Welcome!
    kct1975 likes this.
    01-01-2021 02:06 PM
  1. Replies: 2
    Last Post: 01-04-2021, 03:39 PM
  2. Screen protector?
    By Denisew 1972 in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 01-04-2021, 11:56 AM
  3. Replies: 2
    Last Post: 01-01-2021, 02:07 PM
  4. Help with reflashing 8.0
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 01-01-2021, 01:10 PM
  5. Help with reflashing 8.0
    Last Post: 12-31-2020, 11:51 PM
