1. Justas Bukauskas's Avatar
    Hi. After update to Android 11 swipe gestures working not so good as before the update on Note 10Plus.
    Swipe from bottom to go to to home screen works very poor. Same problem with swipe and hold to open recent apps.
    Maybe someone else noticed this problem on Note 10?
    01-16-2021 08:51 AM
  2. Javier P's Avatar
    Are you using the stock launcher or a third party one?
    01-16-2021 09:44 AM
  3. hooligan03's Avatar
    No issues seen on my Note 10+. I installed Android 11 last night. Gestures working fine for me. Have you booted into Recovery and cleared cache? If not, I would try that out.
    J Dubbs likes this.
    01-16-2021 09:46 AM
  4. billyhousemover's Avatar
    I've noticed a difference as well. It's almost like the area you begin the series is smaller now.
    01-16-2021 09:48 AM
  5. billyhousemover's Avatar
    *begin the swipe*
    01-16-2021 09:49 AM
  6. mustang7757's Avatar
    I would try clearing cache in recovery like mentioned above .
    J Dubbs likes this.
    01-16-2021 10:02 AM
  7. Justas Bukauskas's Avatar
    Cleared cache - didnt help.
    Made a phone hard reser - didnt help.
    Buggy android update......
    01-17-2021 01:44 PM
  8. me just saying's Avatar
    Note 10+ already getting updates? where's my update?
    anyway, try turning gestures ott, restart phone, then turn them back on.
    J Dubbs likes this.
    01-17-2021 02:07 PM
  9. fanisk's Avatar
    Frankly didn't notice any change!
    I am using the stock launcher.
    01-19-2021 04:10 PM
  1. Replies: 1
    Last Post: 01-16-2021, 10:14 AM
  2. How do you know if you get the Samsung credit with preorder?
    Last Post: 01-16-2021, 10:04 AM
  3. Need help with a Samsung Galaxy Nexus Sprint
    By galaxynexushelp21312 in forum Sprint Galaxy Nexus
    Last Post: 01-16-2021, 03:03 AM
  4. Have you ever had trouble with zoom meetings with the Kindle fire 10
    By Android Central Question in forum Amazon Kindle Fire HD
    Last Post: 01-15-2021, 11:43 PM
  5. HDMI adapter with Ethernet input
    By Simow L in forum General Help and How To
    Last Post: 01-15-2021, 08:09 PM
