1. tneihouse's Avatar
    I have a Samsung Note 10+ and just had the Android 11 update done and I totaly hate it. There are a few things that it did that I don't like and I havent found a way to change them.
    1. Before the update when I got a Facebook Messenger message there would be a bubble that popped up on the edge of the screen and that does not happen anymore.
    2. When I open anything that changes the screen to landscape, after I close the app, the home screen stays in landscape and I have to put the phone to sleep for it to change back to portrait mode.
    3. In the YouTube app, I used to be able to rotate the screen and it would follow it. Now when I rotate the phone it does not. I have to push the full screen icon in the app and it will turn it to landscape, but only one direction, and when I try to go back out of full screen it stays in landscape mode and won't change back to portrait mode.
    I have turn on and off the auto-rotate and it does nothing. I have also looked into the settings for the display and apps for the bubble.
    Any help would be greatly appreciated.
    02-17-2021 03:47 PM
  2. SM_Androidz's Avatar
    ya, this is why it's always better to stay on older firmware.
    02-17-2021 04:59 PM
  3. Duard's Avatar
    Not having any of those issues on Android 11 on pixel 4a5g.
    02-18-2021 08:18 AM
  4. J Dubbs's Avatar
    Updates suck lol. If it ain't broke don't fix it....if it is broke blame the last update
    cmgam likes this.
    02-18-2021 08:20 AM
  5. 2kchevy's Avatar
    No issues with my note 20U love the update
    02-18-2021 10:21 AM
  6. B. Diddy's Avatar
    Glitches related to an OS version update are typically more device-specific than generalized for that OS version, so I moved this from the Android 11 forum to the Note10 forum.
    02-18-2021 09:34 PM
  7. anon(10614692)'s Avatar
    These are app issues, Not Android 11 issues. The apps you refer to are not compatible with Android 11 except for point 2 which you may resolve if you clear system cache.
    02-19-2021 05:16 AM
  8. trucksmoveamerica#AC's Avatar
    There wouldn't be any need to blame the last update if it wasn't forced on us, IMO.
    J Dubbs likes this.
    02-19-2021 11:19 PM
  9. 2kchevy's Avatar
    .mm
    03-03-2021 02:19 PM
  10. adegbenroagoro's Avatar
    Even after just a security patch I ALWAYS clear the cache partition. I'm having no issues whatsoever. In fact the fingerprint reader seems faster. Have you done so.
    J Dubbs likes this.
    03-05-2021 03:40 PM
  11. mustang7757's Avatar
    OP hasn't confirmed anything yet.
    03-05-2021 07:59 PM
  1. Pixel 5 battery drain idle issue?
    By dmxjago in forum Google Pixel 5
    Last Post: 03-06-2021, 06:07 PM
  2. Sim card issues?
    By PortablePete in forum Samsung Galaxy S21 & S21+ & S21 Ultra
    Last Post: 03-03-2021, 12:14 PM
  3. Wireless Charging Paused on Verizon Note 10+ after Android 11
    By GaryBMD in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 02-20-2021, 08:52 AM
  4. Android box help needed
    By Patrick Darragh in forum Android TV
    Last Post: 02-18-2021, 01:24 AM
  5. Android Auto Developer Mode with Missing App?
    By michail71 in forum Android 11
    Last Post: 02-17-2021, 02:50 PM
