1. Tim-ANC's Avatar
    Plus model. It was working fine before the update. When I select it in settings and hit the lock screen button, I see the clock momentarily then it goes full black. Back in settings it shows AOD toggled off again.
    I have the app AOD Notify. Thinking it might be interfering with AOD, I force stopped the app. No help. Wondering if I should un-install the app next? Or is it unrelated?
    Lock Screen Always On Display not working after 3.1 update.-screenshot_20210320-083347_settings.jpg
    03-22-2021 02:10 PM
  2. Tim-ANC's Avatar
    Is it toggle to tap.to show .
    No, it was set to shows always. I toggled tap to show. Hit the lock screen and tapped. Nothing happened. Went back to settings and it still showed always on toggled and AOD off again.
    03-22-2021 02:59 PM
  3. mustang7757's Avatar
    Try clearing cache in recovery, then test again
    03-22-2021 03:03 PM
  4. Tim-ANC's Avatar
    Sorry, can't see how to do it. Can you tell me how please?
    03-22-2021 03:18 PM
  5. mustang7757's Avatar
    Sure , turn off the phone just before it starts press volume up/power button same time once in recovery select clear cache and tap.power button after that select reboot phone and power button once again.
    Tim-ANC likes this.
    03-22-2021 03:27 PM
  6. Tim-ANC's Avatar
    Something I just noticed. If I get an email notification it won't show on the lock screen until I unlock it then lock it again. Confirmed with 3 different accounts
    03-22-2021 03:34 PM
  7. Tim-ANC's Avatar
    Wiped cache. Still same issue. Lock screen will show clock for a split second then blank out. In settings, it toggled AOD off again
    03-22-2021 03:43 PM
  8. mustang7757's Avatar
    You have AOD notify app off ?
    Tim-ANC likes this.
    03-22-2021 11:21 PM
  9. Tim-ANC's Avatar
    Good thought. Just un-installed it. AOD working now. Maybe the app doesn't play well with 3.1. I'll contact the dev. Thanks
    mustang7757 likes this.
    03-23-2021 07:03 AM
  10. mustang7757's Avatar
    Yeah probably , Your Welcome!
    Tim-ANC likes this.
    03-23-2021 08:56 AM
  11. gsparks2's Avatar
    Do you have power saving mode on?
    03-25-2021 03:31 PM
  1. Replies: 42
    Last Post: 04-14-2021, 04:38 PM
  2. Replies: 2
    Last Post: 03-22-2021, 10:08 PM
  3. Mystery symbol on Android phone.
    By ParableGuy in forum Ask a Question
    Last Post: 03-22-2021, 03:24 PM
  4. So after being hacked repeatedly. . .
    By hurrysteam in forum Android Security Talk
    Last Post: 03-21-2021, 07:53 PM
  5. So after being hacked repeatedly. . .
    By hurrysteam in forum Software Development and Hacking
    Last Post: 03-21-2021, 01:24 PM
