1. koshki009's Avatar
    It used to be so easy...just click holidays on or off, but now that's gone.
    Is there a way to add US holidays to my calendar that doesn't require opening a Google calendar? Or purchasing an app?
    05-09-2021 05:26 AM
  2. B. Diddy's Avatar
    I can't see a way to do that using only the native Samsung calendar. I checked on my A32 5G, but I assume the Samsung Calendar app is the same as the one on the Note10.
    05-09-2021 11:31 AM
  3. mustang7757's Avatar
    If you open Samsung calendar then tap.4 bars upper left >next to your email tap the" v" tap the dot to show then tap again to not show US holidaysHow do I add US holidays to Note10+ calendar without using Google?-screenshot_20210509-131453_calendar.jpg
    05-09-2021 12:19 PM
  4. B. Diddy's Avatar
    If you open Samsung calendar then tap.4 bars upper left >next to your email tap the" v" tap the dot to show then tap again to not show US holidaysClick image for larger version.
    The problem there is that the Holiday calendar is actually part of the Google calendar account, and the OP doesn't want to use Google.
    05-09-2021 07:01 PM
  5. mustang7757's Avatar
    If it Google , im not sure I don't use that calendar
    05-09-2021 07:05 PM
  6. B. Diddy's Avatar
    Yeah, I was checking on my A32 5G -- you can see that calendar is part of the dropdown calendars for the Google-associated account. There's no Holiday calendar under the Samsung account. I also checked the Subscribed Calendars option, and there are no holiday calendars there either.
    05-09-2021 07:14 PM
  7. mustang7757's Avatar
    On my screenshot there's a holiday option with my Gmail account in Samsung calander
    05-09-2021 07:35 PM
  8. B. Diddy's Avatar
    Right, I'm using the Samsung Calendar app as well -- but the Holiday calendar is part of the Google account calendar. That's the only way you can get a holiday calendar to show up in the Samsung Calendar app, as far as I can tell. It sounds like the OP doesn't want to use their Google account to get a holiday calendar. (Or if the OP just means they don't want to use the Google Calendar app, but are otherwise fine with using the Google account calendar in their Samsung Calendar app, then by all means, that's a solution.)
    05-09-2021 07:48 PM
  9. mustang7757's Avatar
    Yeah true without a Google account don't see it also
    05-09-2021 08:32 PM
  10. koshki009's Avatar
    I'm uncomfortable with the amount of intrusion Google has into our lives. I've never used the Google calendar and, frankly, resent that they control the holidays on my phone.
    I can set up recurring events on my own (at least the ones that don't float), but I was hoping to find a one click solution.
    It shouldn't be this difficult.
    05-11-2021 07:34 AM
  11. mustang7757's Avatar
    I'm surprised Samsung account we don't have holidays only under Google
    05-11-2021 08:21 AM
  12. B. Diddy's Avatar
    My guess is that it was a decision on Samsung's part, so if there's anyone to resent, it's them rather than Google.
    I know that a privacy discussion wasn't the main point of your question, but it's worth pointing out that Google is very transparent about its privacy policies (and does give you a pretty decent amount of control), while Samsung isn't necessarily better -- see this article: https://www.computerworld.com/articl...ling-data.html. (JR Raphael is the tech journalist I trust the most, and he's very much independent.)
    05-11-2021 10:37 AM
  13. jhimmel's Avatar
    Well, not only under Google. My Outlook and Exchange accounts have the holidays too.
    mustang7757 likes this.
    05-11-2021 05:35 PM
  14. mustang7757's Avatar
    Ahh good to know , didn't have my outlook sync
    jhimmel likes this.
    05-11-2021 06:32 PM
  1. How to get notifications to play on my phones speakers while BT devices connected
    By PavementPilot in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 05-15-2021, 09:21 PM
  2. Samsung Cloud to One Drive Migration
    By Zakjoe1234 in forum Ask a Question
    Last Post: 05-09-2021, 11:15 AM
  3. My old number is lost how can i install the old imo?
    Last Post: 05-09-2021, 11:09 AM
  4. What is sprint DM and what does it do
    Last Post: 05-08-2021, 06:52 PM
  5. My phone sinlm reader is blocked jow easy to open
    Last Post: 05-08-2021, 11:25 AM
