1. Gary_Berg's Avatar
    I've got a Note 10 (factory unlocked) that I bought new at Bestbuy running with an AT&T SIM. Since ATT is going to require VOLTE starting in January I wanted to confirm that the phone is running VOLTE.
    Model is SM-N970U1.
    Is there a setting I can confirm this with?
    05-16-2021 09:16 AM
  2. B. Diddy's Avatar
    Under Settings>Connections>Mobile Networks​, do you see an option for Advanced Calling, HD Voice, Enhanced 4G, or anything similar?
    https://www.androidcentral.com/how-e...galaxy-note-10
    05-16-2021 12:11 PM
  3. mustang7757's Avatar
    Unlocked don't show VOLTE , we do get WiFi calling , but carrier version probably have it
    05-16-2021 02:27 PM
  4. Gary_Berg's Avatar
    Nothing about VOLTE or Advanced Calling or anything like that under Mobile Networks.
    However, this seems to imply it'll work (PDF):
    https://www.google.com/url?sa=t&sour...hetKH_v9vTKe4N
    I'm just concerned that my Note 10 might suddenly not work on ATT starting in February. I don't see any way to turn it on. I will say that recently i discovered that WiFi calling now works which it didn't used to.
    If it won't work ud rather make a planned transition to T-Mobile this fall instead of having to scramble in February.
    05-17-2021 09:50 AM
  5. joeldf's Avatar
    AT&T blocks out a lot of mobile network related settings that most other carriers allow to be set. Even unlocked phones if supported by AT&T.
    The Note 10 is one such phone.
    AT&T has a list of supported devices after the 3G shutdown. I tried to link it but the forum keeps re-writing the link so that it won't work. It's supposed to link to a PDF on AT&Ts site.
    The unlocked Note 10 will continue to be supported - it's the N970U1 on that list.
    Here's a screen shot of just the first page...
    B. Diddy likes this.
    05-17-2021 10:21 AM
  6. sulla1965's Avatar
    Yes the note 10 plus should get HD voice.
    05-18-2021 02:13 PM
  7. Gary_Berg's Avatar
    I think the original version of that PDF didn't have the U1 model listed.
    You would think that somewhere in the menus you would find mention of HD Voice or VOLTE or something!
    05-19-2021 09:39 AM
  8. joeldf's Avatar
    Not on AT&T phones. They would prefer to just make those settings for you.
    That list has been recently updated - this is just the first page with all the Samsung phones listed. They added some newer released A#2 models.
    05-28-2021 09:39 AM
  1. GPS feature on Samsung A01 gone berserk
    By 25544 Norad in forum Ask a Question
    Last Post: 05-17-2021, 01:45 AM
  2. Why my phone is not able to switch on in gionee X1
    Last Post: 05-16-2021, 10:23 AM
  3. Why WhatsApp call disconnects and mutes when screen turns off in samsung note 9?
    Last Post: 05-15-2021, 08:06 PM
  4. Why cant I get my messages on my s10+ to my 2019 Gmc Terrain ?
    Last Post: 05-15-2021, 11:02 AM
