How do I fix this annoying Zoom Out issue with my camera???
SpookDroid
Ambassador
Jul 14, 2011
19,283
531
113
Have you run camera module diagnostics ('secret' test mode menu)? Does the same thing happen when using a 3rd party camera app or just in the stock one? Have you tried selecting a different picture quality setting and seeing if that has any effect?
L0n3N1nja
3,629
4
If clearing data/cache on the camera app doesn't work I'd try safe mode next. As a default app it should work in safe mode.
It's also possible the camera module has had a hardware failure, but to rule that out usually requires a full factory reset.
w8wca
