Note 10 or Note 10 plus
amyf27
9,913
286
83
Curious what model and type everyone got. I pre-ordered the 256gb Sprint Note 10 plus in Aura blue 3 Best Buy
Pre ordered both, I'll go to best buy and check out both to see which one I like more. Most likely going to keep the Plus model since it's more of a value compared to the smaller one.
I'll decide in the next few days, worst case I'll let both of them go thru and then decide which one to keep during the return period.
Note 10+ aura glow, don't know storage as I didn't have an option to select any and it didn't specify in the description, didn't say 5G or not either so I'll just have to wait and see
N10+ because I like the expandable micro-sd storage and the larger screen/battery.
Cheers,
BR
Was this close to ordering the glow but I felt, while it's different and interesting , I might get fed up with it. With white and black being the only alternative on T-Mobile, I ordered the unlocked blue 256GB via Samsung.
10+ 256GB 5G in Rainbow Skittle colour.
Courier delivery pm of the 23rd.
( only Aura Glow and black available here all models. And no pre order deals or incentives as always)
I was worried about the Glow as well. It looks good, but I thought it might be too mirror looking, so I went with blue as well.
I went with the Note 10+. While the 10 is a good size, the 10+ is the same width, and only slightly taller than my XS Max. I was also a little worried about battery life on the smaller model.
Unlocked 10+ 256gb in Black. I like the Glow, but it's way too flashy for me; I like clear cases.
to be honest I don't really think the smaller 6.3 is much of an upgrade from the Note 9
ATT Note 10+ Black 512gb... wondering if I should have stuck with the 256gb considering all the delays last year with 512gb models. Also, upon second thought, 256gb seems like it should be enough so I’m not sure why I went 512... I think it was because of the small difference in price. I’m an app hoarder but I don’t think I can find enough apps to use all that space. LOL
BNI Bisnis
