08-17-2019 01:25 AM
31 12
tools
  1. jejb's Avatar
    There was a rumor that the selfie camera hole might double as a notification LED. I didn't catch after the announcement if that was the case or not. Anyone confirm if that's true or not? I put a lot of value in being able to just look at the phone and see if the LED is blinking to let me know I need to check it, so that'd be a tough loss.
    TJohnsonmp01 and SZQnl like this.
    08-08-2019 02:16 PM
  2. JHBThree's Avatar
    It's just like the S10. No notification light of any kind out of the box.
    08-08-2019 02:20 PM
  3. mlbyanks11's Avatar
    This is actually incorrect. If you download Samsung good lock application off the galaxy app store it has the notification light option for the camera punch hole.
    08-08-2019 04:23 PM
  4. icnmayhem's Avatar
    its also useful for "yes, I did in fact place the phone on the wireless charger correctly"
    kevinpleasants likes this.
    08-08-2019 04:25 PM
  5. JHBThree's Avatar
    It is not incorrect. Out of the box, it has no notification. You have to download additional software.
    Ry, nuangel2 and Carrie Greicar like this.
    08-08-2019 09:49 PM
  6. ShinyTop's Avatar
    Out of the box the always on display shows an icon for the notifications and when battery is full. At a glance.
    08-08-2019 10:39 PM
  7. Johnston212's Avatar
    Unless it is fundamentally different from the Note 9, then it's not even remotely the same thing
    08-08-2019 10:59 PM
  8. ShinyTop's Avatar
    My note 10+ has the features and in color so at a glance is even easier. I did not get the 9 but the 10+ is a definite improvement on the 8+.
    08-08-2019 11:02 PM
  9. Johnston212's Avatar
    It might be improved some, but I get so many notifications that an LED notification, or something close to that is better than the AOD
    08-08-2019 11:07 PM
  10. ShinyTop's Avatar
    Okay, to you but my experience is the AOD is better and provides the at a glance notification that was asked about. To each his own.
    08-08-2019 11:09 PM
  11. Johnston212's Avatar
    How many notifications do you usually have at one time? I sometimes have 20+ notifications and the AOD icons only show a few icons and then +X for the extras. Some notifications are more important than others, but the AOD doesn't let me sort that, whereas a notification light shows me that I have an important notification among the rest, but might also let me customize the colors of the light.
    And the edge light doesn't really count, since it is not a constant notification.
    08-09-2019 12:22 AM
  12. JHBThree's Avatar
    They were asking specifically about the notification light, not at a glance or AOD. AOD isn't as useful as a light for a lot of people, because you have to look at the screen
    08-09-2019 04:04 PM
  13. crester's Avatar
    No... YOU are wrong. That's not the same as an LED. The Edge Lighting app by Samsung just lights up the camera hole momentarily when a notification comes in. It doesn't keep flashing continuously like a true LED does until you clear the notification.
    08-09-2019 04:12 PM
  14. jejb's Avatar
    I looked through Goodlock but didn't find an option for that. Can you tell me where to find it in that app? Wanted to try it on my N9 to see how it works.
    Thanks
    08-09-2019 04:13 PM
  15. msm0511's Avatar
    Thanks
    It probably wouldn't be there on the version of good lock for the Note 9 because it doesn't have a punch hole camera.
    Nostromo79 and ROE_HUNTER like this.
    08-09-2019 04:19 PM
  16. Mike Dee's Avatar
    I get some many notifications that you might as well assume it's on.
    Nostromo79 likes this.
    08-09-2019 04:27 PM
  17. Johnston212's Avatar
    Even then, how do you discern between important ones and everything else
    08-09-2019 10:39 PM
  18. Blues Fan's Avatar
    How did you get the Note 10 so soon?
    barryl85 likes this.
    08-10-2019 02:29 AM
  19. jejb's Avatar
    That's what I figured too, but thought I'd ask. After watching some YT vid's about the Good Lock LED notification, it seems this is a non-issue. That's assuming it also works on the Note's. There are also some stand alone apps to make it work.
    08-10-2019 06:20 AM
  20. boufa's Avatar
    Omg...it's an LED, perhaps both "sides" need to settle a bit.... You all use your phones different, that's cool. Neither is right, neither is wrong.
    That said the LED is gone. Adapt to the new format, or don't buy the phone are your only 2 choices.
    Jewels81 and ivanwi11iams like this.
    08-10-2019 02:35 PM
  21. Mike Dee's Avatar
    I don't discern. I chose what notifications I want based on which apps I want to notify me.
    08-10-2019 08:37 PM
  22. jejb's Avatar
    That's apparently not true. You just have to use Good Lock or other apps to get a notification LED working.
    08-10-2019 09:08 PM
  23. Mike Dee's Avatar
    I don't think it's a constant blink. If it's like the S10 it's just an initial notification
    08-10-2019 09:28 PM
  24. SZQnl's Avatar
    I'd miss the RGB NLED as well (currently have the Xiaomi MI 5). It's very convenient when I am not right next to the phone, e.g. cooking, cleaning, chatting with friends or colleagues at work. Can instantly judge whether it's important or not. Sounds strange when I try to explain it but in practice it's simple and effective.
    AOD I'm not sure as I have never owned one. Are the notifications visible at a distance?
    Maybe some of the official cases (LED Back Cover, LED Wallet Cover) can display custom notifications. No idea how visible they are though.
    08-10-2019 09:53 PM
  25. jejb's Avatar
    You are correct, at least for the Good Lock fix. But apps like LED Me Know will keep it active.
    08-11-2019 06:25 AM
31 12
  1. any good case deals out there yet??
    By bigpapa7272 in forum Samsung Galaxy Note 10 & Note 10+ Cases & Accessories
    Last Post: 09-08-2019, 10:21 AM
  2. Galaxy S9 now says IMS status is off. Now I can not send any MMS messages at all.
    Last Post: 08-11-2019, 10:41 AM
  3. Notifications not showing properly
    By mawallace in forum Samsung Galaxy S8 & S8+
    Last Post: 08-11-2019, 08:19 AM
  4. How do I add brightness adjustment to the notification panel on a Galaxy A70?
    Last Post: 08-09-2019, 09:40 AM
  5. White box in the notification bar.
    Last Post: 08-08-2019, 01:33 AM
