1. corvette72778's Avatar
    These are the best of the best accessories I found and bought. Feel free to post other good accessories for the Note 10 that you came across.
    45w Car charger:
    NextGadget 63W Car Charger with USB-C PD2 (45W) and USB-A QC3 (18W) for MacBook, Google Pixel, iPad, iPhone, Android and Nintendo Switch and Others https://www.amazon.com/dp/B0793QF52R...cUvbUpU6599875
    USB- C PD Car charger cable:
    NIMASO USB C to C Cable 5A Fast Charging, 3.3ft 100W PD USB C to USB C Cable Nylon Braided Cord with E-Marker Chip Compatible with Google Pixel 3a/3/2 XL, MacBook, Galaxy S10/S9/S8, Nexus 6P and More https://www.amazon.com/dp/B07QRSHLSD...cUvbUpU6599875
    Dual wireless charging pad (12.5w/7.5w)
    https://rover.ebay.com/rover/1/711-5...2F273905939643
    Single wireless charging pad (15w):
    Wireless Charger Stand 15W, Black
    https://forums.androidcentral.com/e?...token=U471dQz4
    Samsung 45w charger
    45W USB-C Fast Charging Wall Charger, Black
    https://forums.androidcentral.com/e?...token=6kxRK7hZ
    Amazon inexpensive highly rated 45w charger:
    USB C Charger,GUKIMAX 29W 45W... https://www.amazon.com/dp/B07R3TP5GG...cUvbUpU6599875
    Samsung Dex Pad
    https://rover.ebay.com/rover/1/711-5...2F153590734778
    kevinpleasants likes this.
    08-12-2019 05:26 AM
  2. Gary02468's Avatar
    I don't think there are any essential N10 accessories that don't come with the phone. If there were, Samsung's advertising would have to acknowledge them as required extra purchases.
    Wireless chargers and car adapters are helpful, but I'll continue to use the ones I already have. I plan to use my pre-order credit to get Samsung's AKG BT earbuds.
    Nostromo79 likes this.
    08-12-2019 07:20 AM
  3. corvette72778's Avatar
    One of the biggest features of the Note 10+ is 45w charging. 45w chargers are sold separately. Despite being capable of 45w charging the Note 10+ only comes with a 25w charger.
    debdroid1a and Nostromo79 like this.
    08-12-2019 07:38 AM
  4. evohicks's Avatar
    For the people with a need for the headphone jack, you can either buy the official adapter (which is not available yet) or there are lots of others probably alot cheaper.
    Before you purchase you might want to get the dual adapter allowing you to charge and listen to music at the same time like this for example..
    USB C to 3.5mm Adapter, Kolpop 2 in 1 Aux Type C Headphone Adapter with DAC Chipset Audio and USB-C PD Fast Charging for iPad Pro 2018, Pixel 3/2XL, Huawei P30 Pro, P20/Mate 20 Pro, Xiaomi 6/8 & more https://www.amazon.co.uk/dp/B07KMRJ2...cUvbUpU6599970
    I will probably go for this one...
    https://www.mobilefun.co.uk/baseus-u...r-silver-69427
    1raygin likes this.
    08-12-2019 07:49 AM
  5. Gary02468's Avatar
    Yup. I don't expect to have a use for 45W charging, but if ever I do, I'll get the adapter at that time. (For the sake of battery longevity, I use the slowest charging that meets my needs. I rarely need to do more than just charge overnight.)
    08-12-2019 08:09 AM
  6. bupac's Avatar
    Number one accessory you should get: a dongle
    srgonu, recDNA, Nostromo79 and 1 others like this.
    08-12-2019 08:47 AM
  7. debdroid1a's Avatar
    I rarely keep my phone long enough to worry about battery longevity. However I did keep the Note 5 because I never could get the Note 7. But I'm never far from a charger.
    I may look into the charger, but right now it's not a concern for me.
    Additional cables for the headphone jack might be a must have. Not sure yet.
    DeX pad isn't needed, so that's not a must have.
    08-12-2019 09:39 AM
  8. ctk4949's Avatar
    I think a case and maybe screen protector.
    Katrina White1 likes this.
    08-12-2019 11:32 AM
  9. Serkle K's Avatar
    I don't usually plug my phone in, to charge, I usually use the wireless charging. So, if I have the official Samsung car charger that came out with the S7/Note7 series, will that be enough to top off while in the car or should I get a newer one? Right now, that's the only "essential" accessory I need, other than a case and screen protector. I already have those.
    Also, is it bad to use the older Samsung Fast wireless Chargers, or is it recommended to replace those? Of the 4 I have, only 1 of them I had to pay for, the others I always got as a free accessory. That would be a lot to replace.
    08-13-2019 06:21 AM
  10. j_hansen's Avatar
    if you are used to getting by on wireless charging then I don't see any point in spending money on accessories, chargers will work just fine and not be slower than you are used to
    08-13-2019 07:05 AM
  11. Javier P's Avatar
    Thread moved to the new Cases & Accessories sub-forum.
    08-13-2019 09:26 PM
  12. boufa's Avatar
    Your older chargers will work, and provide power up to their design limits. If you have an S7/N7 rapid charger, you will see similar batter charging performance from it with the Note 10.
    08-14-2019 08:53 AM
  13. EMGSM's Avatar
    45w Car charger:
    NextGadget 63W Car Charger with USB-C PD2 (45W) and USB-A QC3 (18W) for MacBook, Google Pixel, iPad, iPhone, Android and Nintendo Switch and Others https://www.amazon.com/dp/B0793QF52R...cUvbUpU6602725
    NIMASO USB C to C Cable 5A Fast Charging, 3.3ft 100W PD USB C to USB C Cable Nylon Braided Cord with E-Marker Chip Compatible with Google Pixel 3a/3/2 XL, MacBook, Galaxy S10/S9/S8, Nexus 6P and More https://www.amazon.com/dp/B07QRSHLSD...cUvbUpU6602725
    https://forums.androidcentral.com/e?...token=OKQAYtsx
    Samsung 45w charger
    https://forums.androidcentral.com/e?...token=atSghZxq
    USB C Charger,GUKIMAX 29W 45W... https://www.amazon.com/dp/B07R3TP5GG...cUvbUpU6602725
    Samsung Dex Pad
    Thanks for posting this. I'm getting the NextGadget car charger.
    08-14-2019 10:24 AM
  14. recDNA's Avatar
    I'd be afraid the 45 watt car charger would overheat the Note 10 and drain my car battery. Have you tried it?
    08-14-2019 11:12 AM
  15. mustang7757's Avatar
    If phone built for it I wouldn't worry.
    08-14-2019 11:14 AM
  16. recDNA's Avatar
    I remember how hot my Note 7 got in the car!
    08-14-2019 12:17 PM
  17. Fr0gburp3r's Avatar
    If the Samsung 45w charger is built like the OnePlus 7 Pro 30w charger, the charging brick would heat up, not the battery, which would keep the battery safe from overheating and deminish the lifespan.
    08-14-2019 12:37 PM
  18. mustang7757's Avatar
    That's a whole different phone with issues and not capable of 45w charging
    08-14-2019 01:40 PM
  19. Katrina White1's Avatar
    Yea, but that was a bomb
    kj11 likes this.
    08-14-2019 04:59 PM
  20. recDNA's Avatar
    Yes the last great Note we may ever see. 16/9 ratio with all the bells and whistles. I like my Note 9 but oh that Note 7. I hated to give it up. Funny though it's why I got the LG V20 and I really loved that phone too. If it didn't have an LCD ghosting issue I never would have bought the Note 9.
    08-14-2019 07:31 PM
  21. Nostromo79's Avatar
    Yes, because there will come a time...
    08-14-2019 08:37 PM
  22. nonie's Avatar
    If the phone is gonna fast charge using included 25w cable and brick why would a wireless 15w charger be an essential accessory?
    08-17-2019 02:49 PM
  23. svtcobra's Avatar
    I don't remember the last time that I used the wired chargers. 100% of my charging is wireless. So it does make a difference to me.
    08-18-2019 10:07 PM
  24. Serkle K's Avatar
    When I first got my Note8, when it launched, I only used wireless charging, especially at home. The only time I used world charging, was when I was in the car, to top off between destinations. Now, I find myself needing wired charging more often. It's definitely more convenient to have the wireless charging, especially around the house.
    recDNA likes this.
    08-19-2019 05:46 AM
  1. Note 10+ Screen Protector
    By ProfesserBird in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-17-2019, 12:56 PM
  2. Can the front facing camera cutout be hidden on the note 10 plus?
    By Chitown28 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-12-2019, 01:59 PM
  3. why i have screen that says cabel charging often i plug my charger
    Last Post: 08-12-2019, 12:59 PM
  4. Replies: 2
    Last Post: 08-12-2019, 08:05 AM
  5. why is my note 8 showing processing failed when i try to update my software
    Last Post: 08-12-2019, 06:11 AM
