I'm looking for a clear case that wont yellow , or maybe very minimal as I have decided to pick up the Aura Glow color way , I saw a thread for the note 9 saying that the VRS Design was great an minimal to no yellow , wanted to know if its true?
Do you have experience with them ? if so what would you rate them?
I like Ringke Fusion Clear on my S10+. The edges are turning slightly yellow about 4 months on. The back panel remains perfectly clear. I see they’re also selling a version of the clear that has smoke grey edges. That won’t turn yellow. I intend to pick one up for my Aura Glow Note 10 Plus.
It really depends on the materials. TPU tends to yellow. Polycarbonate does not. My N9 and S9+ had essentially the same case (different branding but looked identical). It has a matte colored edge with polycarbonate back. Haven't found one looks it for the N10 series though. Amazon just delivered one with a tempered glass back, but the sides are probably a clear TPU. I'll have a better look at it when I get home.
