1. BB_PP's Avatar
    I am living in country where i can get p30 pro. I am Note user since n8 but now bit bored. I m on edge to buy p30 pro instead of note 10+. Am i going to miss anything by buying p30 pro?
    08-13-2019 06:56 AM
  2. mgbosshogg's Avatar
    Does a P30Pro have an SPen? There is your answer.
    kj11 and cwbcpa like this.
    08-13-2019 07:37 AM
  3. BB_PP's Avatar
    I just use S pen for notes! I can type. Why need to pay 400$ more
    08-13-2019 12:27 PM
  4. j_hansen's Avatar
    wouldn't even consider something that isn't a Note so it's a NO from me :-)
    rsmin and kj11 like this.
    08-13-2019 12:36 PM
  5. sulla1965's Avatar
    Well if $400 more means some bills don't get paid, then go with the P30. But if the $400 isn't an issue, then I'd go with the Note myself. But the note series isn't for everyone, so get whatever you prefer.
    Alan Sims likes this.
    08-13-2019 01:23 PM
  6. rsmin's Avatar
    New too.
    08-13-2019 03:18 PM
  7. buzzy3970's Avatar
    You're in a Note 10 forum so I'm sure you know what the majority will say lol...
    kj11, Alan Sims and bhatech like this.
    08-13-2019 05:09 PM
  8. bojackr1's Avatar
    I'd get the P30 Pro. Especially since you've already indicated that you're bored with the Note Series and it'll save you $400. And if you don't like it you can always come back.
    Enjoy that P30 Pro!
    EMGSM and Alan Sims like this.
    08-13-2019 05:13 PM
  9. jeetu4444's Avatar
    All depends what's your use..
    I use Note 9 and Mate 20 pro daily...
    Love both of them... Getting Note 10 + now...
    mgbosshogg and Alan Sims like this.
    08-13-2019 08:00 PM
  10. Golurk's Avatar
    If you want the best camera on a phone get the P30 Pro. If you want the S Pen, significantly bigger and slightly better performance get the Note 10+.
    Both are great phones and have more or less the same amount of cool features, big batteries and good displays (the Note 10+ has a slightly higher resolution but it isn’t noticeable in most cases).
    Due to political complications there is some doubt as to current Huawei phones’ future in terms of accessing the Google Play store and Google apps but Huawei have promised to keep updating their current phones as normal and that they will have access to Google Play.
    08-27-2019 10:57 AM
  11. cwbcpa's Avatar
    Sounds like you should get the P30-pro.
    I'd miss the S-Pen, but I'm not you. Sounds like you don't need it or value it so save some money and try the P30 Pro.
    08-27-2019 11:55 AM
  12. Hermes Hidayat's Avatar
    If you need the zoom and macro. Get the P30P. If not get the N10+.
    08-27-2019 12:01 PM
  13. EMGSM's Avatar
    Enjoy that P30 Pro!
    Well said!
    08-27-2019 12:18 PM
  14. comestim's Avatar
    No one know for sure how long before Huawei will be getting android updates. It sounds like the next version of their phone will not even have android on it and have their own OS.
    08-27-2019 01:26 PM
  15. Anthony Martins Rock's Avatar
    well...if you do not use the Spen and you are not bothered about the possibility of the end of Google access and Android in the possibly near future then Huawei phones are a great option for their price/feature value.
    08-28-2019 02:42 AM
  1. samsung fast charge 10000 is on but will not accept charge or charge phone
    Last Post: 08-14-2019, 04:36 PM
  2. my Samsung galaxy j6 or 7 is tinted yellow and idk how to fix it
    Last Post: 08-13-2019, 05:54 AM
  3. Is the Ravpower wireless charging pad compatible with Alcatel or ZTE
    Last Post: 08-13-2019, 01:54 AM
  4. Recommendations on a 3a Xl or 3Xl
    By RC51 RIDER in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 08-13-2019, 01:25 AM
