blackmasta
yes..it's a must for me. I have a huge amount of music and I am using a 400gb micro sd card for my music. I can't live without a phone with a micro sd card slot.
I am using my SD card. I have so many photos that I've kept from previous phones that it would take forever to transfer them between devices. Just moving the SD card from one device to the other is so much easier.
You should always keep backups (preferably multiple), whether you use the SD card or not. If you use the card or not is up to you, but don't rely on it or your phone as your only storage option, as you've seen first-hand.I am on the fence about this as when my phone broke my SD card became corrupted. I thought I lost the 9000+ photos and 400+ CD albums I had on it. Thank God everything was already backed up with Google. I started to cry in the phone store when the rep brought all my "stuff" back for me!!
I agree ,just dont trust it ...but use to load software updates without computerAdd that to the unlimited storage Google gives you when uploading photos with the Photos app.
As for me, I don't think I will ever use an SD card in a phone ever again. I've been burned a few times to get me to not use them anymore.
Most music does not take you a lot of space unless you are storing high resolution files which I do. As to streaming, unlimited data plans solve the using up data issue.There are certainly ppl that fall into both use/need and never used/no idea. Personally, storage expansion is critical to me. Just as ppl have said on board memory is all they need, but if that device is broken your pix, downloads, etc are all lost. Some will go for cloud upload of pix which is good, but you have to pay for that in MOST cases. I also store music on my phone. 20-30GB of it. The whole purpose of having local music is to avoid excessive data usage, or when data isn't even available. The lack of microSD card combined with the gross look and boring/no features have stopped and will continue to stop me from even considering a Pixel. Especially at flagship prices. As for using on the Note, clearly I would.
I still use SD cards and Cloud storage. I find it terribly convenient to store my photos and documents on the SD card and it also allows me to move many of my apps to the SD card, freeing up more internal memory. I tend to have a wee bit more apps installed on my phone than the average user.
Not only this, but apps constantly write to their storage locations, which will cause an SD card to corrupt prematurely. It's so risky that even in the photography world, they recommend reformatting the card between sessions instead of deleting the photos. The reformat only rewrites the registration files, leaving the actual photo data alone, and thus saving write cycles.Do Not move your apps to memory card on note 10
Internal memory on note 10 is ufs 3.0 Wich is 5 times faster than your external storage
You'll slow down your phone , plus with 256 gb at least + sd card , there's no need to transfer the apps even if you have 500 apps on your phone
Here's a memory comparison
https://fossbytes.com/ufs-3-0-features-comparison-microsd/
That's what I thought to until I lost 5,600+ pictures during a phone swap. I'll never use an SD card again. With 256gb of base storage I'll have 4 times the storage I have ever used.
Out of curiosity, but does the note 10 + support this card?
https://forums.androidcentral.com/e...2Fmb-fa256g-am-mb-fa256g-am%2F&token=F-REa4ib
Would this be a better replacement as a better micro sd card to use instead? I have a 512GB SD card and I do tend to take lots of footage and I do editing as well, but would this card work with the 10+ for everyday use?
