08-01-2020 11:12 AM
136 1234 ...
tools
  1. Daniel Bader's Avatar
    How fast is the fps on screen vs on the back ?
    Has the FPS improved from the S10+
    Not that I can tell. It appears to be the same sensor with the same endemic speed issues as on the S10 series. The sensor's also placed a little higher up on the screen (at least on the Note 10+) which took me a bit to get used to but it shouldn't be an issue after a couple of days.
    EMGSM and sweetypie31 like this.
    08-16-2019 12:16 PM
  2. CKwik240's Avatar
    Can you try out the 3d scanning feature please?
    tbbiggs likes this.
    08-16-2019 12:20 PM
  3. tbbiggs's Avatar
    I 2nd this.
    08-16-2019 12:55 PM
  4. criminal_bg's Avatar
    There is indeed!
    is it built in?? from the OS, or do you need to use 3rd party apps like for the S10 series
    08-16-2019 01:24 PM
  5. Andrew Martonik's Avatar
    Saw someone ask about the "ring" around the camera when using face unlock, similar to the S10. Is that present on the note 10+?
    It does the same light-up animation around the front-facing camera as the S10
    08-16-2019 03:41 PM
  6. Andrew Martonik's Avatar
    Besides write to text, is there anything else new with Samsung Notes and how is the sound quality? Thanks in advance.
    Seems effectively the same to me.
    08-16-2019 03:41 PM
  7. Andrew Martonik's Avatar
    Some claim it comes with a screen protector. Did yours? What kind?
    Just like the S10 series, there's a super basic screen protector installed. If you don't like screen protectors, you'll peel it right off and be much happier. If you do like screen protectors ... you'll peel it right off and put a better one on. It's pretty simple and cheap-feeling.
    EMGSM, MrPibb01, bhatech and 3 others like this.
    08-16-2019 03:42 PM
  8. Andrew Martonik's Avatar
    Is the Blue clearly blue or not quite Blue?
    It's very blue.
    Apple2Droid likes this.
    08-16-2019 03:42 PM
  9. Guyinbox's Avatar
    Camera impressions compared to a pixel 3?
    08-16-2019 03:43 PM
  10. Andrew Martonik's Avatar
    How do you take a screenshot? Still Power/Bixby + down volume? I assume hand gesture wave is still there as well.
    Volume down + power button, but you have to just press briefly rather than press and hold. A press and hold of that combo sends you into the power-off menu by default. You can still screenshot with a palm swipe or with the S Pen as well.
    Androidcaz likes this.
    08-16-2019 03:45 PM
  11. Andrew Martonik's Avatar
    Working the exact same for me as the S10+. Meaning it works fine, but it isn't particularly fast or consistent compared to ones like the OnePlus 7 Pro. I really wish Samsung could've made some improvements here.
    sweetypie31 and qnet like this.
    08-16-2019 03:45 PM
  12. Andrew Martonik's Avatar
    There's a wide-angle camera, and a telephoto camera. Those are the only places the Note 10+ is better than the Pixel 3's camera experience. The Pixel 3 still beats it in the main camera and selfie department.
    Guyinbox, sweetypie31 and MRS DIVA like this.
    08-16-2019 03:47 PM
  13. EMGSM's Avatar
    Thanks.
    08-16-2019 03:53 PM
  14. sweetypie31's Avatar
    After the pie update my edge lighting works sporadically and it definitely doesn't work with the screen off .Have they fixed the edge lighting feature ? Is it better or still the same as on the note 9?
    08-16-2019 04:07 PM
  15. Duncan Sharp's Avatar
    Hey, Daniel here. We just got a few Note 10+ units into the studio and because there's no review embargo, we thought we'd take a few questions from you fine folks.
    So ask away — what are you curious about with the Note 10+? We'll spend a couple days checking back here for new questions, and some of the Q+As will be posted in our ongoing review, which you'll be able to find right here tomorrow afternoon ET.
    Hi, will the review go up today? Are you working on easy coast time?
    Thanks
    08-16-2019 06:38 PM
  16. kj11's Avatar
    Yep! Holding those two buttons now triggers the power menu but if you quickly hold power + down volume you take a screenshot. I still prefer the palm method, which works really well.
    Screen write with the sPen is my preferred screen shot method
    08-16-2019 08:19 PM
  17. BBurg_16827's Avatar
    does it support RCS like the 10e?
    08-17-2019 03:49 AM
  18. o4liberty's Avatar
    Google's messaging app supports RCS as long as your carrier does.
    08-17-2019 09:45 AM
  19. stuckingoo's Avatar
    I second the battery test request. And not like the ridiculous way everyone else does it by running it into the ground with cpu intensive processes for hours on end. Most of the time the phone is on standby. How well does it do on standby. And with widgets running. I have a Max and want to get rid of it but not if the Plus is 25% worse with battery life which has been my experience through the years.
    jhendo5013 and Nostromo79 like this.
    08-17-2019 12:12 PM
  20. corvette72778's Avatar
    How does the battery life of the Note 10+ compare to the Note 9?
    08-17-2019 02:12 PM
  21. YankInDaSouth's Avatar
    As a current Pixel 3 user, this concerns me
    08-17-2019 02:36 PM
  22. BBurg_16827's Avatar
    I preordered the Unlocked version through Samsung and I have AT&T, will it still be supported or is it only for carrier branded phones?
    08-17-2019 08:11 PM
  23. o4liberty's Avatar
    Both parties need to have RCS and I have a unlocked pixel on tmo and it works when the other party has the same. It will take a few more years before all carriers use this protocol.
    08-17-2019 08:14 PM
  24. BBurg_16827's Avatar
    I ask if it's carrier branded only because on this list, it shows that my GS9+ is supported, but I have an unlocked (through Samsung) that doesn't allow Android Messages advanced features (even when I type to other samsung users)
    08-17-2019 08:45 PM
  25. miamiborn79's Avatar
    It shouldn't. The cameras on most high in flagships have gotten so good that it's not that big of a drop off.
    YankInDaSouth likes this.
    08-17-2019 11:04 PM
136 1234 ...
  1. Can’t upload in 4K?
    By CFster in forum Google Pixel 3a & Pixel 3a XL
    Last Post: 08-16-2019, 08:39 AM
  2. Note 10+ shipped notification
    By Mr-Guy in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-15-2019, 11:08 PM
  3. Why has the drop down settings display increased in size?
    Last Post: 08-15-2019, 12:24 PM
  4. If I clear my credentials will I lose all my pictures and stuff on my phone
    Last Post: 08-15-2019, 12:05 PM
  5. Why does sdm veiwer keep showing up in activity
    Last Post: 08-15-2019, 11:36 AM
Tags for this Thread
