TheMiz
If I'm not mistaken. Visual voicemail, WiFi calling, HD voice.
What are you saying ?
Unlocked models now have their own visual voice mail ..so that's a plus
Sorry. I responded from my phone and it chooses how I respond apparently. I was just listing the 3 things I lost using the unlocked version.
VZW but where I live I have no choice because the others have no cellphone towers within my area. no AT&T, T-Mobile or Sprint will work here.
My note 9 on the unlocked firmware didWhere? My son has an unlocked S10 and no VVM.
I'm not sure how Verizon models are , but yes it does have its own visual voice mail and worked great .I used it on TMobile sim and Att on the unlocked Note 9 firmwareWhen you say that Unlocked models have their own visual voicemail, does it work seamlessly with Verizon service? Is it the same as the Verizon service?
My main concern with getting an Unlocked model is LOSING visual voicemail. I could care less about HD voice or wifi calling.
@bhatech do you have Verizon on your unlocked S10 ?
You had the visual voicemail on yours ?Yeah I have Verizon but no longer have the unlocked S10 in hand since sold it couple of weeks back in anticipation for Note 10 and trading in the pixel 3 now.
You get everything except wifi calling, the vvm is in the phone dialer and not a separate app.
I use Google voice so never tried carrier voicemail
I can try once I get my unlocked Note 10 Wednesday.
Yeah Verizon on unlocked I heard they do work for WiFi callingYou get everything except wifi calling, the vvm is in the phone dialer and not a separate app.
