I'm glad to see others who are not all doe eyed and giddy.
Studies have shown that after spending your hard earned money some people are more satisfied because in their mind they have to justify the purchase.
I like my note 10+ sure, but it is not "amazing", it isn't a huge upgrade over my note 8, and had I gone to purchase it at the store as I did with the note 9 I probably would have left without it, as I did with the note 9.
The hole punch was my main concern before deciding to pre-order (only the 2nd time I've ever done that), but I honestly don't even notice it, and no, I am not hiding it with settings or wallpaper.
I like the wide angle shot, though it pushes objects farther away to obtain that view.
The fingerprint sensor is definitely in a more convenient place for me than the note 8, but it does not work as well.
I haven't tried any of the s pen gimmick features, nor do I plan to try them.
The stereo speakers sound nice.
I've stated many times that I have never used the headphone jack in any phone, so unsurprisingly I do not miss it.
I deleted, not disabled, the preinstalled FB, games, spotify, etc. As many of you recall there was a time when that couldn't be done without root.
There are fewer signal bars than on previous phones, though I have not noticed any negatives from that thus far.
The powershare feature works fine as long as any case on either device isn't too thick.
I have applied a screen protector and have lost no sensitivity as far as I can tell. I know some will look back on my comment about the fingerprint sensor and I assure you that it was not as fast as the one on the note 8 prior to applying the screen protector.
Battery life, I don't concern myself with that due to how easy it is to charge a phone, so no comment.
The weight of the phone even with a bulkier case is lighter than the note 8, not that the note 8 or any phone is heavy.
The speed of the new filesystem is faster. Moving files from my sdcard to the internal storage was definitely faster than my note 8.
I noticed that on my wife's S9 Samsung messages has the enhanced chat features, the note 10 does not even though the app is a newer version.
Also, I experienced a glitch in the matrix last night when i was able to activate the chat features in the Google messages app, the 5 minutes later it was gone.
