06-16-2020 02:06 AM
42 12
tools
  1. amyf27's Avatar
    Several months ago I purchased and I Otti vent mount for my. It's a tad on the flimsy side and the little arms are tiny Plus a smooth case may slide when being held so I have these rubber bands rig on it to keep that from happening.
    I'm going to look into getting something sturdier to use possibly a dash mount. I do have a windshield mount that's very sturdy I might use that for a little while. I like the position of where the air vent is though it's very easy to reach and it's not in the way of my viewing.
    08-21-2019 05:39 PM
  2. o4liberty's Avatar
    I converted to magnetic holders for all of my cars I don't use wireless charging which doesn't work with metal plates.
    BergerKing likes this.
    08-21-2019 05:53 PM
  3. ImNoPrince's Avatar
    I got this a few months ago for my s8+ , used it heavy last week on vacation with Waze running almost the entire time and some other hits with no drop off at all. I need to upgrade to the c3.0 to get the max out of it but very happy so far , very sturdy . Only downside is my last one I could just lift in and out , I forget to let it open before I turn the Jeep off , so have to force pull it out or turn jeep back on for it to open.
    https://www.amazon.com/gp/product/B0...cUvbUpU6613792
    08-21-2019 05:59 PM
  4. tsells's Avatar
    Try www.proclipusa.com
    It's the best phone holder in the industry, as the mount is custom made for every car with no glue, screws, or any damage done to your car. I've been using them for many years and I love this mounting solution.
    08-21-2019 06:16 PM
  5. CKwik240's Avatar
    I concur that they make some good ones. However not all applications are well executed. I have a 2013 Chrysler 300 and the mount is solid. The ones for the previous generation 300 are utter crap.
    I'm using mine with the new iOttie magnetic wireless charger. Unfortunately, iOttie decided to integrate the 17 mm ball into the mount. I had to take the thing apart and do some careful modifications to the ball mount I have for my pro clip to get it to work. The old worked charger mount can easily be mounted to a ball adapter, but the way the arms small ****, it's only a matter of time before they will break from fatigue. That's what happened to me. IOttie replaced it under warranty, but I moved on to the magnetic one and gave the other one to a friend.
    08-21-2019 06:58 PM
  6. Bkdodger1's Avatar
    I use a cup holder as I drive a smaller car don't like the vents covered..
    WeatherTech
    https://www.weathertech.com/products...rtech-cupfone/
    loonie01 likes this.
    08-21-2019 07:45 PM
  7. burrzoo's Avatar
    I have an iOttie vent mount wireless charger too. Like you said, not sturdy. I backed this kickstarter & hope it gets delivered by December.
    Always a risk but this holder looks pretty cool to me.
    https://www.kickstarter.com/projects...ging-car-mount
    delynnie likes this.
    08-21-2019 10:09 PM
  8. burrzoo's Avatar
    I totally miss having a Mophie Charge Force magnetic case/holder setup. Unfortunately, starting with a Note 8,they never could get those cases working right with Samsung phones that have wireless charging. It was so convenient. Mophie never even made a Note 9 Charge force case.
    08-21-2019 10:13 PM
  9. KruseLudsMobile's Avatar
    Proclip
    08-21-2019 11:54 PM
  10. stephenrus's Avatar
    For dash mount I am using Andobil, automatic hold my Note 9 (10+ now) and wireless charge. Excellent customer service. Remember to register after you buy to get warranty. Hope that help.
    08-24-2019 03:29 PM
  11. durandetto's Avatar
    I have the iOttie fast wireless charger. It comes with a disc you can stick anywhere then mount the suction cup on it. It will charge even when using Google maps and Bluetooth. Not sure the wattage though.
    08-25-2019 12:20 AM
  12. NIZMOZ44's Avatar
    I use this one with a pro clip mount. Works great.
    iOttie Easy One Touch Wireless Qi Fast Charge Car Mount Kit || Fast Charge: Samsung Galaxy S10 S9 Plus S8 S7 Edge Note 8 5 | Standard Charge: iPhone X 8 Plus & Qi Enabled Devices | + Dual Car Charger https://smile.amazon.com/dp/B0754NDN..._7MNyDbE88KX35
    08-25-2019 07:07 AM
  13. NIZMOZ44's Avatar
    Never affix this sort of suction base to a windshield which sees direct sunlight. A photochemical reaction releases the plasticizers from that soft, clear PVC compound and the suction cup itself reverts to a gooey, viscous state.
    Again, I use a pro clip mount with this. It doesnt use that suction cup.
    08-25-2019 09:04 AM
  14. durandetto's Avatar
    I have the same charger. How does it attach to the proclip mount? I was thinking about ordering one.
    08-25-2019 09:06 AM
  15. NIZMOZ44's Avatar
    That mount from proclip, with this swivel, and this adapter and get the pro clip for your car. Works like a champ.
    ARKON APGN-VSM Vehicle Specific... https://www.amazon.com/dp/B002ACP2FY...cUvbUpU6619561
    and
    https://www.proclipusa.com/product/t...sSearch=215500
    durandetto likes this.
    08-25-2019 09:08 AM
  16. NIZMOZ44's Avatar
    I'll take a picture shortly and post it. I posted it, but its waiting on admin approval.
    08-25-2019 09:09 AM
  17. NIZMOZ44's Avatar
    Some pictures.
    Looking at a sturdier Car mount.-20190825_114731.jpgLooking at a sturdier Car mount.-20190825_114739.jpgLooking at a sturdier Car mount.-20190825_114752.jpgLooking at a sturdier Car mount.-20190825_114803.jpg
    tsells, Bkdodger1 and daninbluemd like this.
    08-25-2019 11:56 AM
  18. zocster's Avatar
    Approved
    NIZMOZ44 likes this.
    08-25-2019 12:32 PM
  19. tsells's Avatar
    Thanks for posting. That's a great set-up.
    I love Proclip, but this wireless set-up makes it better!
    08-25-2019 01:59 PM
  20. NIZMOZ44's Avatar
    Yes it does. I love it actually. Charges while I am using Waze on it. Easy to pop in and out with one hand.
    08-25-2019 02:06 PM
  21. NIZMOZ44's Avatar
    Forgot to mention, you will need this adapter with that one from Amazon too to order with your proclip. You will just have to drill out the holes a little on it to get the amazon adapter screws to fit through them to put the nut on.
    tsells likes this.
    08-25-2019 02:09 PM
  22. tsells's Avatar
    Wow. Lots of stuff ($$$) needed for this set-up but I think it will be good for me as I spend a lot of time in the car.
    Thanks for posting!
    08-25-2019 02:28 PM
  23. NIZMOZ44's Avatar
    Thanks for posting!
    Yep. But you can take it with you to any car. Just buy a new pro clip. And it's a solid mount. My phone doesnt shake at all and has never came out.
    tsells likes this.
    08-25-2019 02:45 PM
  24. Bkdodger1's Avatar
    Simple cup holder
    08-25-2019 03:34 PM
  25. CKwik240's Avatar
    That was a great charger.... Except when it breaks. It snaps shut so hard, it puts a shock load on the tab that eventually causes a fatigue failure. They really needed to put a damper to allow the closer action down without reducing clamping force. It was replaced under warranty, but I have it away and went with the new magnetic version.
    I agree the proclip hardware can be great, but that's not the case for all cars.
    08-26-2019 04:46 PM
42 12
  1. Replies: 15
    Last Post: 09-03-2020, 12:58 PM
  2. Replies: 12
    Last Post: 06-16-2020, 07:12 AM
  3. Wi-Fi Calling with unlocked Galaxy S20 on AT&T?
    By Bzguy2148 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 06-15-2020, 07:24 PM
  4. Replies: 9
    Last Post: 06-15-2020, 02:00 PM
  5. 2 Weeks in and Battery looks good!
    By Lepa79 in forum Google Pixel 4 & Pixel 4 XL
    Last Post: 06-14-2020, 12:28 AM
