So I hooked up a Belkin USB C hub with a keyboard and mouse and monitor to my brand new Note 10+ and was actually able to use it like a desktop/laptop. I currently have spotify playing on a bluetooth speaker while typing up this post! Nice!!!!!
Is this what the link to windows app leads to?
I tried using the desktop app and put the phone into transfer file mode like it said to but the app on the desktop won't recognize the phone. Not much troubleshooting documentation yet on this thing.
Did you install the USB Debugging driver during installation?
So when you are using Dex on your computer are you using the internet connection from your phone or from the computer?
Unless there's something on under the hood that I'm not aware of, DeX uses your phone's Internet connection. I can tell because when I use it with my Macbook at work, I'm able to use DeX to access sites that are blocked by my work's internal network.
(No, not those sites. For some reason my work blocks any web page related to alcohol, which is annoying when my coworkers and I are planning happy hour. DeX was useful for this.)
Here is the link to download Samsung Dex for Windows or MAC.
https://forums.androidcentral.com/e...s%2Fsolutions%2Fsamsung-dex%2F&token=-pInxWfq
https://forums.androidcentral.com/e...s%2Fsolutions%2Fsamsung-dex%2F&token=NH6FcSMF
No, that's different. As of the Note 10+, DeX is two slightly separate things.
1. The "old" DeX where you connect a usb-C to HDMI cable to an external monitor or TV, and get a Desktop interface.
2. New DeX,where you plug your phone into a computer via usb-C to usb-C (or usb-C to usb-A, if that's all your computer has), and install the Samsung DeX app on your Windows or Mac computer. The app on your computer will act as a "monitor" and let you control your phone from your computer, but with a desktop-like interface. Also you can drag and drop files from your computer into the DeX window.
Hope that helps! You should try DeX out, it's pretty great. I'm using it right now to post (using method 1).
OK, I find that Dex is more useful than Link to Windows.
https://forums.androidcentral.com/e...s%2Fsolutions%2Fsamsung-dex%2F&token=gm4b3hyh
