    Hi, just got my note 10+ and coming from note 9 I noticed that I'm unable to change the picture quality on settings, so idk if I'm using the top quality for it.
    Samsung blocked us from customize the camera resolution?
    * There's only video resolution settings
    Thanks in advance.
    08-22-2019 06:12 AM
  2. Nakrohtap's Avatar
    Are you sure there's not a drop-down next to each aspect ratio to select the resolution like on the Note9?
    08-22-2019 07:17 AM
  3. Misterb's Avatar
    Thanks in advance.
    I'm having the same issue
    08-22-2019 08:47 AM
  4. strikeIII's Avatar
    Thanks in advance.
    When you select the aspect ratio you are choosing the resolution. 3:4 is the highest res. They changed this starting with the S10 line.
    08-22-2019 08:55 AM
  5. Aharon Shimberg's Avatar
    Yeah there's no option anymore over there
    08-22-2019 11:37 AM
  6. Aharon Shimberg's Avatar
    I see thank you for the light in this matter. I would preferred to keep with the old style, it's more clear of what you are doing with the resolution.
    Thx
    08-22-2019 11:40 AM
  1. Overheating warning when taking pictures
    By kmcochran in forum Google Pixel 3a & Pixel 3a XL
    Last Post: 08-23-2019, 06:15 PM
  2. Replies: 4
    Last Post: 08-21-2019, 03:48 PM
  3. Change camera resolution og S10?
    By Pizzabager in forum Samsung Galaxy S10 & S10+
    Last Post: 08-20-2019, 10:35 AM
  4. Why is my camera dimming pictures almost completely black?
    Last Post: 08-19-2019, 02:53 AM
  5. Best dual flash drive to back up pictures/videos
    By gnGracie in forum Samsung Galaxy S9 & S9+
    Last Post: 08-18-2019, 08:35 PM
