1. Duncan Sharp's Avatar
    On the iPhone I used to keyword search apps all the time, difference being that it would automatically bring up the keyboard so I wouldn't have to click in the search bar.
    Any way to do this on the note 10 plus?
    08-22-2019 11:05 AM
  2. strikeIII's Avatar
    Swipe up to get into your application tray and type in the search bar at the top.
    08-22-2019 11:29 AM
  3. bhatech's Avatar
    Not on the default launcher and such a oversight IMO. As a workaround what I do is add a finder shortcut in the dock and I use that to search apps. In order to do that first you need to add finder shortcut as an app which you can do in finder settings. Clicking on the finder app automatically puts the cursor in the search box and brings up the keyboard.
    Duncan Sharp likes this.
    08-22-2019 11:30 AM
  4. bhatech's Avatar
    But that doesn't automatically put the cursor in the search box and bring up the keyboard when you swipe up which was his original question.
    08-22-2019 11:31 AM
  5. Duncan Sharp's Avatar
    [IMG=360x760]https://uploads.tapatalk-cdn.com/20190822/bbb566f83c2a0750f92039bb3e1aa683.jpg[/url][IMG=360x760]https://uploads.tapatalk-cdn.com/20190822/d8eff433b62a0c3bdd1d4e0aaa700ec1.jpg[/url][IMG=360x760]https://uploads.tapatalk-cdn.com/20190822/bf696e374f5a699ddf4706e2a6b52531.jpg[/url]
    Perfect solution.
    Thanks very much
    bhatech likes this.
    08-22-2019 11:50 AM
  6. andrew_ackley's Avatar
    You can do that on the stock launcher out of the box if you swipe down on the home screen. I switched it to bringing down the notification shade on mine tho.
    08-22-2019 02:14 PM
  7. gyounk's Avatar
    Finder! The name of the Macintosh built in app that let you view, search, rename, delete (drag to.the trash can), and launch applications and files.
    It was the first app that auto launches when you boot a mac .
    08-22-2019 02:43 PM
  1. Q release is simply 'Android 10'
    By Bla1ze in forum Android 10
    Last Post: 09-03-2019, 08:03 PM
  2. How do you install 2 sim cards in note 10 plus?
    By Duncan Sharp in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-22-2019, 01:26 PM
  3. Anyone tempted on note 10 plus
    By farocco in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 08-22-2019, 12:04 PM
  4. Bittersweet feeling returning Note 9
    By PhabPhan in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-22-2019, 11:46 AM
  5. Initial Note 10 + Issues :(
    Last Post: 08-22-2019, 10:49 AM
