08-28-2019 07:53 PM
40 12
tools
  1. haganjeff's Avatar
    Note 10 Plus - Unlocked on Verizon. Was hoping for closer to 8 hrs SOT.. About 90 minutes better than my Note 8, but still a little disappointed.. Also, as I was typing this with 4% left the phone shut itself down and would not restart till it was plugged in for a couple minutes.. That happen anyone else? Never happened on previous Notes.
    08-22-2019 01:50 PM
  2. strikeIII's Avatar
    It's a little too early to tell and the device is probably still "Learning" your battery usage. Give it a few weeks and see how the battery life is then.
    08-22-2019 02:00 PM
  3. billyjoebob007's Avatar
    Ya, the batt usage today on the note 10+ is about the same as yesterday on my old s9+, about the same usage amount too.
    haganjeff likes this.
    08-22-2019 03:40 PM
  4. linkiik121's Avatar
    I hope so.... battery is worse than my old note 9.
    lsmith9523 likes this.
    08-22-2019 03:40 PM
  5. stuckingoo's Avatar
    20 hours and almost 6 SOT looks good to me. Thanks for this. Will like to see other results.
    08-22-2019 03:50 PM
  6. Lepa79's Avatar
    Note 10 Plus - Unlocked on Verizon. Was hoping for closer to 8 hrs SOT.. About 90 minutes better than my Note 8, but still a little disappointed.. Also, as I was typing this with 4% left the phone shut itself down and would not restart till it was plugged in for a couple minutes.. That happen anyone else? Never happened on previous Notes. https://uploads.tapatalk-cdn.com/201...fa61f8a6cb.jpg
    Massive screen with 6 hours SOT. not sure you can expect much more than that.
    haganjeff and Super Spartan like this.
    08-22-2019 04:08 PM
  7. Mooncatt's Avatar
    This is actually normal. Battery meters tend to be less accurate when nearing zero. As batteries wear out, it'll happen more often and at higher percentages. It's possible your battery is already weakened from the factory, and draining it so far will only make things worse. Leave that sort of testing to the reviewers. They get their phones for free and don't keep them long, so it's no skin off their backs if the battery is worthless in a matter of months due to the abuse they put them through.
    08-22-2019 04:21 PM
  8. haganjeff's Avatar
    I'll add that I am using the phone at full WQHD resolution, not sure how much affect if any that would have on the battery.
    08-22-2019 04:27 PM
  9. evohicks's Avatar
    That will have an effect on the battery life for sure, give it a couple of weeks for the battery to learn your patterns.
    I take it you're using the Snapdragon 855 chip and not the Exynos chip?
    08-22-2019 04:46 PM
  10. haganjeff's Avatar
    Yes, Snapdragon.. I'll run a test back at FHD.. I watched a review of 10 things to do immediately and he said to turn set it to WQHD and get the full benefit of the screen.. Both look great, so I test and see if I gain battery life. Thanks!
    08-22-2019 04:54 PM
  11. Lepa79's Avatar
    Overkill. I bet you won't notice a difference going WQHD vs FHD. Saving in battery is probably about 30 to 45 minutes SOT
    08-22-2019 05:03 PM
  12. NIZMOZ44's Avatar
    It's never good to take your battery down to 0% especially Lithium ones. They may have programmed into the phone to shut down with a few % left to save the batteries life. Some other manufactures do this (Apple).
    08-22-2019 06:07 PM
  13. jeetu4444's Avatar
    Did u start fresh or took a backup from old phone... Starting fresh is recommended for a new phone
    08-22-2019 06:20 PM
  14. rushmore's Avatar
    Old. LOL
    If I get same battery life as my "old" Note 9, I'll be happy. Bigger display with less than 10% more battery, seems a net zero gain. 855 is a much faster chipset.
    08-22-2019 06:33 PM
  15. Chitown28's Avatar
    why does it matter if you start fresh or not? Almost everybody gonna wanna backup some things from there old phone to new. I backed up my wifi passwords, call history, contacts, text messages because i wanted that stuff on my new phone to be there and that was done from google drive and i restored some things i needed from samsung restore data as well. Again stuff i needed on my new phone so no other way to do it.
    08-22-2019 07:04 PM
  16. Mooncatt's Avatar
    Transferring independent files generally isn't an issue. The concern with transferring stuff like apps via backup/transfer services is that sometimes a glitch may happen during the transfer process that causes an app to misbehave. That's why it's best to just re-download apps from the Play store.
    Serkle K likes this.
    08-22-2019 07:22 PM
  17. tbbiggs's Avatar
    I'm *thrilled* with my first day battery life.
    08-22-2019 07:41 PM
  18. stuckingoo's Avatar
    Did you use widgets?
    08-22-2019 07:55 PM
  19. linkiik121's Avatar
    Old. LOL
    855 is supposed to be more efficient, is it not?. Yes, bigger screen that's also less than 10 percent bigger.From what I see its the drain sitting doing nothing compared to the note 9.
    08-22-2019 08:52 PM
  20. kj11's Avatar
    Too soon?
    debdroid1a likes this.
    08-22-2019 09:26 PM
  21. fredwardnelson's Avatar
    What are your power settings like? If you're running everything at max 5:48 screen on time is really good.
    On my Note 9 I set my power settings to medium, no difference in my mind (I came from an OnePlus). I easily got 9:40 to 10:00 screen on time. I'm sure with my Note 10+ it'll be even better. The battery life on this thing is amazing.
    08-23-2019 12:36 AM
  22. lcs101's Avatar
    I'm *thrilled* with my first day battery life.[IMG=485x1024]https://uploads.tapatalk-cdn.com/20190823/8e02cd617a80c9c1a8b3038d78144537.jpg[/url]
    Out of curiosity, what do you do that has you spend 7 hours out of 15 hours on your phone?
    08-23-2019 07:52 AM
  23. tbbiggs's Avatar
    Ha! That's not a typical day for me. I recently ruptured my Achilles and had surgery Wednesday, so yesterday was a day spent with my leg up doing nothing. Thus, exorbitant phone time.
    08-23-2019 07:56 AM
  24. lcs101's Avatar
    Ouch, sorry about the achilles. Had a friend of mine do the same (while celebrating a Super Bowl touch down) a few years ago.
    Makes sense in terms of time on your phone, of course. I was thinking maybe it was job-related.
    08-23-2019 08:02 AM
  25. tbbiggs's Avatar
    Nope. I do spend a lot of time on the phone (self employed, and I'm my own secretary) but not nearly that much on the average day.
    08-23-2019 08:09 AM
40 12
  1. how to turn off battery charging info
    By SGN9_2019 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 01-11-2020, 09:42 AM
  2. Galaxy watch battery usage
    By Dominik Bakos in forum Samsung Galaxy Watch
    Last Post: 08-26-2019, 09:06 PM
  3. Turn Off AOD Battery Charging Notification
    By michael4man in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-22-2019, 11:19 AM
  4. Galaxy watch battery usage
    By Android Central Question in forum Samsung Galaxy Watch
    Last Post: 08-22-2019, 10:56 AM
  5. Galaxy watch battery usage
    Last Post: 08-22-2019, 09:47 AM
