goji26
I've noticed the same issue sitting at my desk at work. The signal and data speed on my Note 10+ is much lower than my Pixel 3 XL.
Where do get the firmware for T mobile... N10+It might be because carrier firmware have the carrier aggression. You can can flash to carrier firmware if you choose so.
Sammobile websiteWhere do get the firmware for T mobile... N10+
Waiting for your updateView attachment 308230
This was at work today. I flashed TMO firmware tonight. I will do same test at work tomorrow and see if any different
Glad you squashed the signal weaker on unlocked model newsYou can see even though signal strength about same, TMO meter shows 4 bars.
I havent tried TMobile firmware yet but I was at this place where my Pixel 3 worked fine on T-Mobile via Google Fi and Note 10 switched from zero bars to no service. So there is definitely some sort of issue
Don't think it's an issue with the phone. I had a Sony Z3 international unlocked and a T-mobile version of the same phone side by side on seperate lines side by side. They performed pretty much the same. I've had several Samsung phones, both T-Mobile and unlocked versions over the years and I have not noticed a difference in connection performance at all.
Not saying you're not having some kind of issue, but it's not ubiquitous to an unlocked phone.
There is truth to Note 10+ not grabbing much signal. I had pixel 3 xl before and in our basement, I used to get 2 bars easily. With Note 10, I am at zero bars to 1 very rarely. Both unlocked.
What app is this?Bars don't matter. T-Mobile software fudges them to make the network appear stronger. Look for a numerical signal strength value:
