Ok, I updated to TMO. All went good. Signal strength meter looks higher but its not. Looks like TMO just makes meter look stronger. I do have HD voice now so thats good though.
I believe HD voice is available on the unlocked model for TMobile/Verizon. Only reason to flash carrier firmware is if you want the perception of better signal with more barsSo you didn't have HD voice before you flashed? I was looking to keep my phone stock, but may end up flashing to get the features if that's the case.
Same with Verizon, everything same as carrier variant for unlocked model on Verizon. AT&T is the crap carrier who doesn't play ball with unlocked models.I don't see so much a issue with TMobile on unlocked version , it's more Att
They use to be goodSame with Verizon, everything same as carrier variant for unlocked model on Verizon. AT&T is the crap carrier who doesn't play ball with unlocked models.
I am using an unlocked on t-mobile. I get everything other then video calling. Not a problem for me I don't use it.
Hopefully Google message app takes care thatOnly other thing would be RCS..."if" they ever implement it.
Rich communication serviceWhat's RCS?
You can see someone writing in a texts or read receipts
Yeah , most can ...but it's a cool to haveI can live without that
