1. CSOReaper's Avatar
    Received my Note 10 plus yesterday. I cannot get the fingerprint sensor to work. I have tried enabling touching with screen protector option, wetting finger a bit, etc. I do have a tempered protector on the screen. It has a circle with a membrane for the fingerprint area.
    It wouldn't work before the protector either.
    Anyone else having this?
    08-22-2019 04:35 PM
  2. tatootie67's Avatar
    No issue here. Other than it's harder with the thumb to register. I tried fingers and it's much easier
    burrzoo likes this.
    08-22-2019 04:39 PM
  3. cache11's Avatar
    No issues othet than it is not as fast as a traditional sensor, but I have only had my phone for 24 hours and still getting used to it.
    08-22-2019 08:30 PM
  4. Gary02468's Avatar
    It works ok for me (with the pre-installed screen protector). Did you receive the ASH4 firmware update?
    08-22-2019 10:28 PM
  5. CSOReaper's Avatar
    Yes, I have that update. Might be my screen protector. I don't want to take it off to check lol.
    08-23-2019 12:04 AM
  6. o4liberty's Avatar
    Having same issue hopefully an update fixes the issue.
    08-23-2019 12:06 AM
  7. CSOReaper's Avatar
    Confirmed, tempered glass protector. Was going to drive me crazy until I removed it and tried. Works fine.
    burrzoo likes this.
    08-23-2019 12:14 AM
  8. Shelacios's Avatar
    The update helped the FPS significantly. It was sketch for me at first. Works very well now.
    08-23-2019 01:13 AM
  1. Android Auto Not Working On Note 9
    By Phillip Babin in forum Android Auto
    Last Post: 08-24-2019, 02:12 PM
  2. Fingerprint scanner needs haptic feedback.
    By CKwik240 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-22-2019, 08:35 PM
  3. Samsung failed to pack Note 10+ in package set to include Note and Buds
    By andresxhm in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-22-2019, 04:03 PM
  4. Note 10+ Health Sensors
    By alodar101 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-22-2019, 01:24 PM
  5. Any good deals now the Note 10 is out? (UK)
    By Wmsi in forum Samsung Galaxy Note 9
    Last Post: 08-22-2019, 12:47 PM
