notefreak
Trusted Member
Charge mine overnight... Once in awhile wireless charge at work but most days just makes it all day till bedtime
Yes, Samsung's recommendation to stay between 20% and 100% (with nothing said against overnight charging) is much less onerous than the other article's recommendation to stay between 40% and 80%. At 20%, I'd start to worry about running out all the way anyway.
Lately it's every 6 months I have issues...Same here. I never keep a phone over a year so charge at night no matter what it is set at. I use for android auto as well, so of course it charges while that is on. So never enters my mind.
Yeah , to do what the other article says is a real burden, it just doesn't support enough evidence for me to do that . I still have my note 9 which is over 6 months old and still have solid battery life like day one . If the battery fails in another year or 2 , then so be it I'll either replace it or get rid of the phone . Battery life you not going get more then 2 to 3 years anyways regardless which method .Yes, Samsung's recommendation to stay between 20% and 100% (with nothing said against overnight charging) is much less onerous than the other article's recommendation to stay between 40% and 80%. At 20%, I'd start to worry about running out all the way anyway.
And even Samsung's milder recommendation is just one of a dozen sacrifices they suggest considering if you're maximally concerned about your battery wearing out. And their suggestion is buried in an obscure help article, not even mentioned in the User Manual. So they don't seem very emphatic about it.
There is no way I am locking myself into a prison of 40-80.
Hahaha
Hi welcome to AC!Yeah, it's March 2022 and I'm conflicted and have been wondering what others thought. I was using a Note 8 and yeah it seems like the battery lost a lot of capacity in the last several years. I tend to use my phone's longer than some people will so I do want them to last. That's why I'm trying to look into it. But the folks talkin about 40 to 80% being inconvenient are so absolutely correct. Seemed like since Accubattery all I do is charge the phone. I just upgraded to the 10 and haven't started using it yet. Sometimes you gotta just charge it a bit. That's just how life is. But overall, when home and able, I'd like to do what's best for the long run of the battery. If the 40-80 thing is so solid why do manufacturers like Samsung keep saying 15-100? I just don't get why all the secrecy I guess. Maybe just so folks are constantly upgrading their phones. If it's all about how many charges cycles that you get out of the battery, then how does charging it more often for less help? That's where I get lost. I'm charging it more frequently. So that's more cycles... Yes? Don't get that. Heard some explanation about not letting them go full 100% charged. But a few years back it was yes let it charge then trickle. So if anybody has any updated opinions on this I'd love to hear them!
Hi welcome to AC!
That 40 to 80% might be the way to preserve the battery degrading but then you have to wonder about that constant charging creating chemical reaction everytime in the battery causing a degradation , Samsung newer phones have a toggle to stop charging at 85% so I'm testing that out from 5 to 85%. I personally had batteries on smartphone last 3 years doing 5 to 100% over the years , so yes 40 to 80 charging is impractical for my everyday use even if I could squeeze another year out the battery most will last between 2 to 3 without severe degradation if not gaming all the time wich is another battery killer .
In the end I say replace the battery when time comes if your holding onto it for longer times as long as the cost is reasonable. I personally would stick to 5 to 100 and enjoy your phone with less charging
That's not bad 93% 30 to 95% not to bad and the only thing I've seen a benefit from 85% toggle is it charges less time , like 10% to 85 in 37 minutesMy 26 month old Note 10 Plus Exynos version has a battery capacity(health) of 93%. I tend to charge it mainly between 30 - 95%. I've noticed the heat generated while charging with the phone switched off is MUCH less so do so as often as possible. Easier since I use 2 phones Battery replacement services from Samsung in my country aren't that good. Using that toggle doesn't fit my lifestyle.
