Usb c 3.5mm adapter that lets you charge and listen at the same time?
jadedangel143
103
Ok, desperately in search of adapter that lets you charge your phone and listen at the same time. Trying to find one before i get my note 10+? Does this exist?
Anthony Martins Rock
129
there are many. Amazon search them out and choose one. perhaps do a YouTube review Search first for the best of the best as I purchased a c-3.5 and there are many crappy ones as a few that actually enhance your sound.
CKwik240
738
18
Since we are also taking about charging, it may be important to consider and look for internal power limits for these splitters. Especially if you're trying to charge at 45 Watts. Might be hard to find such a specification for these though.
jadedangel143
103
I will order a few different ones and report back. Adapter reviews even for just headphone ones are all over the place. i'm not holding my breath for one with 45w fast charging.
KruseLudsMobile
449
Let us know. I've tried a couple and returned them. You have to use a tester to verify the charging wattage is 25W or 45W when the phone is at our below 50%. I've gotten this one and it works well:
MakerHawk USB Power Meter, TC66 USB Tester Type C USB Voltage Meter and Current Tester, 0.96 Inch IPS Color LCD Display Power Tester Multimeter PD Ammeter Voltmeter QC 2.0 3.0 https://www.amazon.com/dp/B07NXRPNP...ag=hawk-future-20&ascsubtag=UUacUvbUpU6629473
KruseLudsMobile
449
Do not do this!
CKwik240
738
18
Do not do this!
Nowhere does that warning say not to use these types of devices. Only that some don't meet USB specifications or have defects. At the very least, I would try and stuck to trusted brands if they exist.
However, I would be careful to pay attention to published power handling specifications and stay within them. The 25 watt and 45 watt chargers may easily overcome this if the e-marker equipped cables can communicate that a proper cable is attached through this device.
