1. felloffthetruck's Avatar
    I have the 512GB SD card from my S10+ that has a ton of pictures, music ETC on it that I want to use with my new Note 10+.
    Will it work fine just plugging it into the Note 10 or should I reformat it with the Note 10 before using it?
    08-23-2019 11:06 AM
  2. bbgpsuser's Avatar
    I moved my SD card directly from my S10+ to my Note 10+ with no reformatting. It is working just fine.
    08-23-2019 11:14 AM
  3. felloffthetruck's Avatar
    Thank You.
    08-23-2019 11:27 AM
  4. Lepa79's Avatar
    No need to format. Unless you want to delete everything on it and street with a clean card. Otherwise just plug it in.
    08-23-2019 12:11 PM
  5. Gary02468's Avatar
    No problems here moving a card from N9 to N10+. Just be sure to decrypt first if it's encrypted.
    08-23-2019 02:24 PM
  6. Liljoe83's Avatar
    I didn't have to when I came from the note 9
    08-29-2019 01:48 PM
  1. Why is my phone zooming in on wallpaper at random times?
    Last Post: 08-23-2019, 07:33 PM
  2. Why does my
  3. Best photo gallery app for the S10+
    Last Post: 08-23-2019, 05:10 PM
  4. I broke the power button S10
    Last Post: 08-23-2019, 10:29 AM
  5. Thorough Walkthru of Galaxy Note 10+
    By Codeworks in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-23-2019, 09:48 AM
